Hi, may I ask the correct transfers for the Norton model 18 1946 girder fork. I have tank badges, side and small one on the top of tank, oil bath too. Did this model have a rear mudguard transfer?
Many thanks
I have a 1939 ES2 with the…
I have a 1939 ES2 with the tank side decals plus one on the rear mudguard, not too sure on the tank top as I have a different tank fitted from the factory. Primary oil bath decal is sometimes varied in its location by an inch up, down, back or foreward. Take a look at ORIGINAL pictures in the books and catalogues. Don't rely on what you see on todays bikes.
I would recommend the plastic stickers with peel off front and back type and not water transfers as they have a grotty yellowish background.
