Hi, I've some weeping from my cylinder base on 1946 model 18. Is there a gasket available for the cylinder base? If so does anyone have a link to purchase one?
Thank you
Previously matthewben_upto…
Thank you, so there isn't…
Thank you, so there isn't one available as such. Looks quite a big job as it's the base? Quite new to nortons, this is my first.
Hi Matthewben, if you only…
Hi Matthewben, if you only have a 'weep', you will have to weigh up the task of removing the complete top end to rectify it (and it may appear back again sooner than you think) to just accepting the oil and simply enjoy the old bikes, oil and all. Remember, old Norton's don't drip oil, they simply leave their mark.
(have you checked the head bolt nuts, they maybe could do with re-tensioning.)
Paul.
Previously matthewben_upton wrote:
matthewben.
its best to make a gasket.use thin gasket paper and a little welseal.
but make sure you line up the gasket with the two oil holes for oil returning from the rockers to the crankcase . i,ve been running es2 engines for age,s and always made gaskets. i do 2 or 3000mls a year. with only a few problems
