For the 2 pin flasher unit can someone tell me which wires go to the B and L terminals?
Is B for Battery or Bulbs and is L for Live or Lights?
I can't find a wiring diagram or any information to determine this. I have the standard positive earth system.
But what are B and L
Alan, thanks for your swift reply with this. I'm still intrigued with what B & L stand for, even though it doesn't matter with the 8FL unit.
(B)attery & (L)oad.. But as…
(B)attery & (L)oad.. But as A.O says, on a two wire sytem it doesn't really matter.
Convention would have it that the live terminal went to the heater (bi-metallic strip). But as the unit could be used on either +ve or -ve earth, it doesn't really matter.
As this Flasher is a Bimetal strip it doesn't matter. If you try and use a modern electronic one then they would be made for Negative Earth.
