Hi. I’m rebuilding a 1960 Dommie 99 engine. At the moment, the course of play seems to be ‘fix one per, then find two more’, so ….
My timing side crankcase has three waisted studs for mounting the magneto. Shouldn’t one of the three studs have a fully parallel shank to act as a pivot for the magneto body to swivel around when tensioning the chain?
I can’t find a plain magneto stud on any of the normal suppliers’ web sites so maybe my three waisted studs are correct after all - I just don’t know.
If there should be a plain stud, anyone know which position it should be in and where I can get one.
Thanks very much.
Thanks Michael. It does seem…
Thanks Michael. It does seem odd to have all three studs as waisted studs but at least I now know that there doesn’t appear to have been a non-waisted stud. I think I’d rather have the three waisted studs than having a bolt with a nut inside the timing cover - at least I can tighten the magneto without diving into the timing side.
Thanks again.
For the 'inaccessible ' lower nut
Treat yourself to a BSA A7/ A10 extended magneto nut. Its about 6" long and means you can easily adjust mag anytime you want to. You won't regret it.
Lots of places sell them.
George.
Longer mag nut
Thanks George, I'd forgotten about these. Not looking for total originality, so I just bought 2 from Feked.com, £4 each!
Magneto Mounting
Just found these notes in the DSNs.
Early Dominators had their magnetos held by 3 external waisted studs (T2245), positioned on the outside of the Timing crankcase shoulder. This also applied to the later Distributor models. However, after 1964 engines saw the lower of these studs replaced by a 5/16” shouldered bolt, with 1/4” thread which was inserted through from the inside of the timing cover. This item making the magneto chain a little easier to adjust but relying on friction to hold the bolt in place.
The big advantage of having 3 waisted nuts is that not only could the chain tension be set but the body of the magneto could be rotated to help fine tune the ignition timing.
Thanks for that information…
Thanks for that information Philip, all very interesting. So it seems that my three waisted studs are correct and actually a good idea! I haven’t been able to find any information about the tension for the magneto chain. Mine has approx 1/4 inch up and down movement- does that sound like the correct amount of slack?
Cribbed Notes
The attachments may be of some help.
If you have a dummy timing cover the suggested distances are fine. Otherwise add just a tiny fraction of a mm more.
Hi Philip. I’ve got a…
Hi Philip. I’ve got a intermediate spindle support plate from Andover Norton so I’ll see if I can get another 1mm or so tension in the chain.
“The magneto is attached to the crankcase by 3 nuts- current models use two nuts also a bolt in the lower position-with its nut inside the timing chest. The studs also the bolt are waisted (reduced diameter) which permits limited movement of the magneto, when the fixing nuts are released.”
As given in my original (and very well stained!) factory manual on twins.
The idea of the bolt at the bottom with nut inside timing chest is that it is otherwise almost impossible to release/ tighten in situ.
Hope this helps with what you need Tony.
