is there any disadvantage in fitting 16 tooth crankshaft/magneto sprockets to a 50s ES2, rather than the standard 15 tooth ?
I think the 59-63 singles…
My 1951ES2 has 16 T sprock…
My 1951ES2 has 16 T sprockets as standard, so as long as they both have the same tooth count, there should be no problem.
I think the 59-63 singles used 16 tooth if I remember right.
I don't have any earlier 15 tooth singles so I can't say. To me the alternator models were the best but that's my opinion! Theoretically you should be able to use either but there must have been a reason for the change. Less tooth wear perhaps?
