Any ideas on spare packing gland for international oil tell tale ?
Looks like felt in a cup.
Supplier of replacement, alternatives from other machines or a home brew remedy, all welcome.
cheers
I have the same question....
I made some leather washers…
I made some leather washers using wad punches and used 2 or 3 to get the approx height. The plunger movement ended up a bit stiff be it cured the leaks. Worth a try and quite simple to do if you have the punches.
Nick.
Hi Jonathan. From what I…
Hi Jonathan.
From what I remember, it was few years ago, the construction and original packing seemed to be the same as you have found. I didn't have any suitable for wadding, that is why I used reasonably soft leather. I built the layers up to approx the same depth as the original packing. The drag I on the plunger only shows itself by not dropping when the engine stops, so I just push it down. The tell tail on my 16H is has not been rebuilt and has only needed adjusting the pressure sleeve to stop any oil leaks.
I have a whitney punch set…
I have a whitney punch set that makes tidy holes in leather .What size Hole?
Excellent informative discussion on Mr. Tell Tale...
...Thank you! I have metric and SAE punches, nothing otherwise... What is Whitney? Whitworth...?
What is the height of that packing?
I have not seen a factory exploded view of the Tell Tale to determine what was fitted from the factory. nor have i tried to remove the packing to see if there is a fiber sort of washer/cup. I do see packing...
Hi Steve, Whitney is the…
Hi Steve, Whitney is the manufacturer of the punches (and its American!) probably the same as your punch . Whitworth is something you are going to be an expert in, as its the thread form that is used in the alloy on your bike along with cycle threads on most other parts. I expect you are familiar with this from your other brit bike. Lets hope your Inter is not a Bastard mixture of Whit,Cycle ,SAE and Metric threads !!!. Seen it done.
Steve there is a good…
Steve there is a good exploded diagram in this WD16H manual of the tell tail etc.
https://www.wdnorton.nl/Downloads/16h%20M&I%20manual%20200dpi%20by%20co…
Regards, Nick
Thanks Robert...
...i have my trusty Dowidat and King Dick wrenches amongst others i bought when i was a lad in the early 70's. All the fasteners fit my wrenches so far...
Telltale drawing distilled.....
...and thanks to Nicholas for supplying source.
Excellent, thanks for sharing that!
i will eventually get to my tell tale...!
.....after getting my hands on a NOS WD telltale and finding it leaks just as badly as my well-used original. I've been mulling re-engineering the seals but haven't settled on a scheme. I have 3 of them so I can afford to sacrifice one to experiments if anyone comes up with a bright idea. Whatever is in there as packing/seal is pretty petrified by now and unidentifiable to me.
