I have acquired a 1952 16H most of the bike is o/k with all the correct parts, but the front end I is wrong, it has long roadholder forks with aluminium sliders andan extrafeature in the right hand slidercastingjust above the brake anchor point I have not seen this feature beforeona slider,and it dose not doanything.It came with an iron full width bolt up8 inch hub. I think I need a 1/2 width hub but do I need an 8 inch or7"to go in the roadholder forks?? HELP
My 55 es2 has the same cas…
That's where the anchor p…
That's where the anchor point for the Manx brake is mounted. Like this attached.
Attachments p1502848896-jpg- Log in to post comments
I'm pretty sure it would…
I'm pretty sure it would have had the 7 inch single sided front wheel. I'm assuming that it has.a plunger frame? The 8 inch single sided brake was only used for a short time, around 54/55, so are hard to find.
Ian
My 55 es2 has the same casting as does the spare of long roadholders I have, no idea what the casting was for but it seems to be common.
Cant help with the wheels I'm afraid
dan
