hi all wanted battery replacements for my ES2 at the moment it has 2 6v could i get a 12v single to fit in the carrier box
Battery replacement
If you go to Paul Goff's site,
There is a table of the dimensions of a very large number of batteries, so you should be able to find one that will suit you.
See: http://www.norbsa02.freeuk.com/goffybatteries.htm
Will also say that on my experience, AGM batteries are very good and worth the premium over a normal lead acid ones.
George.
battery replacement
Hello Alan thanks for the reply my bike is a ES2 500CC SINGLE 1951 Regards Chris
On my 16H I couldn't decide…
On my 16H I couldn't decide whether to go 12v or stick with 6v. So I delayed the decision by fitting two 6v in parallel. Giving me the option of either.
12 volt battery
I used a WKA12-9F2 battery replacement for my 1961 ES2. This battery does fit inside the rubber battery box. I rode all last summer with it without any problems.
Here is the link that I purchased from;
www.apexbattery.com/werker-wka12-9f2-battery.html
Hi Chris, I think it would help if you state which ES2 year/model you are asking about, there are many different type battery carriers used on ES2's.
