hat's very ind of you Dan…
My 52, plunger ES2, came f…
My 52, plunger ES2, came fitted with a model 77 gearbox with no clearance problems. Now fitted with the correct box. From memory, and without taking the primary chain cover off to have a look, I would say with the primary chain off I would be able to squeeze a finger in the gap between the inner cover and the clutch.
I've checked the chain me…
Ok I'll try again, I use…
Ok I'll try again, I use an iPad! You'll need to create a photobucket account, once you've done that you can upload a photo from your album on your Mac , once it's uploaded you can click on it in photobucket, when it loads you'll see a list of links on the right. Copy the link labelled HTML. Then come to this thread and click on the small HTML button that you can see above the box you type a message. Paste the link you have copied and save it, and Bob should be your uncle!
Dan
Thanks Dan. You're a geni…
Wow! Now I'm a genius too…
BTW - new Renolds has arri…
Attachments 1-jpg
Thanks for the pic Barry.…
George. Looking at your pi…
George. Looking at your pic. which isn't too clear it looks as if the bottom nut is only partially engaged on the thread. If its tight it suggests the cover is too far out. John
Well spotted John. I'm su…
Couldn't restrain myself,…
Ooops! BTW John - you were…
Previously George Phillips…
Previously George Phillips wrote:
Ooops! BTW John - you were correct as well. The nut you pointed out was somewhat loose. Am I the right man for the job?? G
George;you are alwaystheright man for the job! Your learning curve is guiding others every time you post. And you are not afraid to postandkeep your descriptions simple. More power tothosewho listen andlearn
Save the pic to photobucket (other providers are available!) and cut and paste the HTML link from photobucketinto the message after clickingthe HTML button above the text box .... simples!
My primary chain is also making too much noise and I'll be investigating that at the weekend, but I doubt its the gearbox, I think they are a straight swap, or so I was told!
