There’s an interesting jubilee in the forthcoming national motorcycle museum auction, it says it is 350, but has a 17 engine number and the headsteady seems to fit?
So i assume it has 350 barrels and Navigator down tube or the listing is wrong!
Dan
Jubilee 350?
Dan & Peter, The Navigator…
Dan & Peter,
The Navigator barrels have 7 cooling fins and from counting the fins on several Jubilee photos I am almost 100% they have 6 which accounts for the difference in stroke and head steady height. Unless I am very mistaken the bike in the picture above has 6 fins so it has a 250cc not a 350cc engine. The gap between the top of the heads and tank looks right for a Jubilee engine too - the Navigator looks 'fuller'. ...................you can tell it is a dark, wet, stormy night out there!!!!
Nick
It's possible
I am currently building a 350 jubilee as a project and it is possible. getting the crank case bored out slightly to accommodate the larger barrel then the crank and top end can be swapped over and a new head steady will have to be made up.. If you join the Norton lightweight Facebook group or Norton specials group I will be documenting all my progress on these groups
Welcome Richard, we’ve…
Welcome Richard, we’ve already spoken! I thought you might find this of interest although it does look like a jubilee! Why not start your own thread here to record your progress, the trouble with Facebook is it’s difficult to build a long story.
ps I’ve asked the auctioneers the question, it says the bike was restored by the museum.
cheers
Dan
Nav/Jubilee
I'm with Nicholas C. on this, the number of fins on the barrel are the give away.
I wish I new this when I was buying a Navigator, the first one I bought had a 250cc engine built up around Navigator (19) crank case.
Oh how I wished for a buyers guide for Jubilees and navigators at that time!
De/Lux Jubilee
This is a straight forward De/Lux 250cc Norton Jubilee.
There is nothing 350 about it.
I’ve had a reply back from…
I’ve had a reply back from the auctioneers, they are changing the listing to 250 .... although the V5 says 350!
Dan
hello again dan .. good idea…
hello again dan .. good idea , atm i am still gathering parts but once i make a significant step like frame painted or wheels refurbed then i will upload some pictures on here ..i am taking as many photos along the way as i can.
I wouldn't bank on this being a 350.
The down tube and headsteady look like they are from Jubilee. The head steady brackets could have been cut off the downtube and welded higher up to accept a taller Navigator barrel/engine. Doubt it.
Or a Jubilee engine as the engine number says.
That rear sprocket looks like Jubilee to me, not the smaller Navigator sprocket for higher gearing.
Centre stand stops are a bit worn as both wheels on the ground.
Tinwork and paint look good. Would look good in a museum.
