Dommie 99 slimline air filter advice
My bike has a single 376 Monobloc with small plastic bellmouth fitted and no filter. It has the air filter box between battery and oil Tank. I see the club does a D shaped one. Are there any other bits i need other than some sort of rubber to the carb to run it with a filter?
thanks
The big box filter that Norville sells needs a carb screw on ring and a rubber connector to link up with the spigot on the box.
Hello Robert thanks for info was hoping to source from the club they have plenty of D shaped filters in stock, grey plastic screw on tube but no rubber was wondering if the filter has an integral rubber that pushes onto that tube?
Here's mine, just needed a rubber connector and two jubilee clips. Oh and an Austin mini air filter cut in half.
Vokes Type Filter
Air Filter fittedDidn't have to cut anything and the battery box fits perfect - you'd never know there was an air filter in there.
Cheers Bob, your bike is lovely btw. I just got one of those roll on centre stands too, so easy to use
Are there any drawings or pics of the original filter arrangement please
