I have a dolls head quadrant cork washer as sold by RGM here:
http://www.rgmnorton.co.uk/buy/dolls-head-gearbox-quadrant-cork_3863.htm
my question is, where do I actually fit this? On the quadrant itself inside the gearbox there doesn't seem to be a logical place to put this. On the outside, there's a space where it fits fairly well though a little lose (see attached image), but although this looks right, I can't see what benefit there is to having it there, as it's not sealing anything?
img-20160618-wa0006-jpg
That's hopeless, isn't i…
Thanks Richard, Even if th…
Thanks Richard,
Even if the cork filled the entire space, I still don't get how it would seal anything, wouldn't any leaking oil come down the shaft on the inside of the brass bush anyway?
Is this just to stop anything leaking on the outside of the bush? and if so would a rubber o-ring do a better job if I found one to fit?
It should stand proud and…
It should stand proud and form a face seal against the large retaining washer. If it doesn't fill the counterbore, it will simply deform.
An 'O' ring may work initially but will flatten and harden whereas a cork washer that remains oily (and it will !) should keep swelling and maintain a light pressure behind the retainer.
That's really useful than…
That's really useful thanks Richard, I didn't know there was a washer under the lever, but that would make sense, I'll need to find one of those as well as getting/making a larger cork washer.
It's amazing how such small things keep stopping my build... I really want to get my Norton on the road this summer!
I found a thicker cork was…
I found a thicker cork washer that had the same inner , so I cut that down to size, (see image). It's not perfectly round, but once it swells up I think it'll do a better job than the one from RGM.
imag1854-jpg
I have successfully used a…
I have successfully used an O ring here but you could also use a fibre washer under the cork seal to space it out.
Two things worth considering.
First, is the bush (available as an off the shelf item from one of the on-line bearing suppliers) inserted to the correct depth. This would influence the pressure on the seal.
Secondly, and this was the case on my bike, I found that the oil was leaking up the spline of the shaft through the lever and under the head of the bolt. A little bit of silicon under the washer and bolt head before assembly and no more oil leaks.
Aled Wrong material, wrong…
Aled
Wrong material, wrong size!
the correct seal as originally fitted by Norton to Dolls Head and the later upright box is made from felt, which you pre-load with grease, both to fit it, and to act as a seal.
The original seal is about 1/2" deep, and with a wall thickness of around 1/8" thick. I got a stock of 1/8" and 1/4" thick felt, and a big set of hole punches, from a firm that sells all sorts of gasket materials, petrol pipe etc, who are always at Stafford, and other major shows, including car. Unfortunately I can't remember their name, but I am sure they were from Liverpool. If you get some 1/8" felt, you could roll a 'tube' to make a suitable seal, especially if you cut the join at a diagonal, or punch cut two 1/4" thick round seals.
There is also a seal made from 1/4" thick felt that goes under the outer cover of the clutch operating worm.
both these seals are clearly shown on pages 47 and 50 of the Norton spare parts list for Models 1, 16H, 18 and ES2 plus 30,40 and Manx, 1946 to 49.
You could also try Russell Motors to see if they have any old stock, but I do remember Les telling me sometime ago that there was a fire in their warehouse, and all the lightweight bits such as these seals got washed away by the fire hoses!
Roger
Roger, are you referring t…
Roger, are you referring to the ratchet plate cam spindle felt washer at the rear of the positive stop mechanism ? Aled's photo looks to me to be of the quadrant spindle / bush on the lower front of the shell.
I can't find a seal listed in the Spare Parts Lists for that location but the WD M&I Manual states :-
"The cam plate quadrant works in a phosphor bronze bush....the outside of the boss carrying the bush is recessed to take a pressed cork oil retaining washer"
Certainly the old boxes that I've looked at have cork there but I would never rule out that wartime practice differed.
My picture is the quadrant…
My picture is the quadrant bush/spindle.
I do have a tin full of felt washers, which may well be 1/4" thick I could try.
Where is the rachet plate cam spindle exactly? If there's felt washer meant to go there I need to find one of those as well.
It's the felt tube at the…
It's the felt tube at the back of the doll's head - there is no oil up there so it only acts as a grease retainer and to keep the muck out. Quite often they can be re-used.
Sorry gents, red face time…
Sorry gents, red face time, I gave out information for the wrong splined shaft, and not helped by being away from here for a few days to post a correction.
The info I gave is correct for the splined shaft of the ratchet plate at the top of the gearbox, not the cam plate quadrant at the bottom of the gearbox.
I've just had a look in my dolls-head gearbox stock at an original gear case, which still had the old seal, which is indeed cork, but the problem with the RGM cork washer in Aled's picture is that it is not thick or deep enough to do the job. As Richard said, it needs to fill up all of the available space between the bush and alloy casing, and also to be slightly proud of the alloy casing so the cam plate quadrant lever presses against the cork, to form a seal.
Also, as Colin said, a dab of silicone under the plate washer stops oil that comes along the splines from leaking out.
If it is any help, the dimensions of the compressed cork washer I took out of the gearbox is 1-1/8" overall diameter, 13/16" inside diameter, and a thickness of 3/16", but you would probably need 1/4" thick from new to allow for compression to seal. Anything less would leak.
The washer is also listed and shown in the 46-49 spares list mentioned above.
Thanks all, I'm happy tha…
Thanks all, I'm happy that my home made cork washer fills the space and is proud enough to press against a washer (though I still need to source that washer). I'll be sure to add some silicone under the washer too. The felt washer behind the dolls head was already in place and in good condition.
Although not running yet,…
Although not running yet, I found in my 1947 upright gearbox that is no sense to fit an external sealing washer, so, I made a pair of cork washers, fitted then inside of the gearbox, sitting tight both at the shafts and against the inner gearbox wall.
Also, the cork thickness allowed the gears meshing face to face and not stepped as without the cork washers.
Attached the pair of shafts with it respective cork washers before fitted to the gearbox.
Hope this help.
Hans in Chile.
img_3782-jpg
That's hopeless, isn't it ? It should indeed fit on the outside and fill the space entirely.
You could try soaking in oil first to see if it expands - but it looks to be composite cork and rubber and may not respond to that treatment - otherwise try making your own from a large cork.
