Regarding pre war speedometers as fitted into the panel in petrol tank on a 1938 Model 18 and 16H :-
Were these chronometric or some other type ?
Were they 2:1 ratio or some other ratio ?
Does anyone know of a supplier for the right angle drive gearbox that turns the speedo cable and that fits on the front hub for a left hand side mounted brake ?
spedo drive
Speedo angle drive gear boxes
Hi Roger,
That's great.
I will phone you
Many thanks
Cheers, David
Hi David your spedo should be chronometric ,i have a few nos spedo angle drive gearboxes my tel no is 07917 334214 regards Roger
