My clutch front plate over the six rubbers is stuck. I have the whole centre off and on the bench. Does it all come apart if I remove the three screws "spring stud nuts" as they are labeled in my E.M.Franks?I tried a socket and the nuts seem to go back and fore a small angle. I don't want to damage something irreplaceable or simply find it has not helped.ThanksDavid Cooper
Just remove the 3 allen sc…
Hi David, The reason the p…
Hi David,
The reason the plate will not come out is most likely to be that the rubbers have degraded and become very stuck to the metal surfaces. You do not need to disturb the spring retaining posts to change the rubbers. Support the clutch centre assembly by restingthe back plateon the open jaws of a large vice or wooden blocks with the hub hanging down with a fairly large gap underneath and then just apply steady pressure on the clutch centre to push it out bringing the plate out with it. The clutch centre has the 3 vanes that bear against the rubbers and they will probably be stuck to those as well. If it won't budge, try soaking the hub in petrol overnight to dissolve the rubberto loosen it.
The reason the post retaining nuts move slightly each way is because there is a flat on the post locating shoulder and a corresponding shaped hole in the back plate. If the posts are tight you can leave them alone, but if you can move them by hand you need to tighten them up and then re-centre punch them to stop them loosening. If you do not like the centre punch method, remove the nuts completely, clean up the threads and then use Loctite. Regards, Richard.
Sorry Jonathan, I didn't…
Sorry Jonathan, I didn't know you had already posted.
Richard.
Thanks for the help both.…
Thanks for the help both. I'll have another bash...it's already very oily of course. I tried earlier but just made holes in the wood. I put the screws back in and tapped them and the cover has come out about half a millimetre. I can't make any more noise tonight. I'll yet sqeezing it next. I can't visualise quite how that works but I'll try to find another drawing. On my Dommie the cover is snug but can be removed.
Previously richard_cornish…
Richard.
Your instructions are far better for the centre that has glued itself together.
I found a clutch that woul…
I found a clutch that would not come apart by rapping so I used Richard's technique but with a vise and a socket.
Excellent! Thanks Jonathan…
Excellent! Thanks Jonathan. I can do that! (I hope).Regards David
Done it!Of course now I'm…
Done it!Of course now I'm in there I find the rubbers appear to be in as-new perfect condition - apart from the fact that they are glued solidly on all surfaces. Thus (I suspect) a rigid drive. They have been there since 1963 (presumably earlier...)So even though they look fine I think they had better be changed. Decide tomorrow...Thanks for your assistance.David
Norton use rubbers that en…
Norton use rubbers that entirely fill the space they are pressed into. That means that when they want to squish they have no space to squish into. This reduces their effectiveness. BSA realized this and redesigned their version of squish rubbers to be oval. The last time I needed a set of rubbers I carved them out of solid rubber in a roughly diamond shape. I couldn't carve a good oval. I can't tell if they are absorbing shocks any better but they are better in theory at least.
I never thought of that bu…
I never thought of that but I am sure you are correct. The bulk modulus of rubber is very high. So it cannot be squashed unless it has somewhere to go. Maybe I should buy new ones but cut them to maybe 2/3 the length. There is almost no end clearance at presen . On the other hand...Nortons were like that from about 1932 to 1970 and nobody as far as I know ever saw it as a problem. The later clutch centre on my Dommie has different hole shape and I can't remember but I think that ended up with some corner gaps. Something else to worry about ( probably unnecessarily)David
Just remove the 3 allen screws. Put a little WD40 or releasing fluid in the seam, turn it over and rap the stud ends on a block of wood. The cover will drift out a little. Get a hook shaped object and pry inside the screw holes and it will come apart. No need to disturb the studs and stud nuts if they are tight. This could lead to trouble.
