Crankshaft end play (float) shims 1956 Dommie 99
Where do you place shims, inside crankcase between bearing and case or on crank between throws and bearing?????
Thanks for your help
J.Peterson
Unless you've  replaced your main bearings with rollers, end float on a 56 Dommie is of no concern as the crank is positively located by the timing side ball journal bearing.
It is a basket case with 2 roller bearings and shims in the parts box. Bearings look ok. Crank is apart with all new bolts ,nuts.Missing the dowel which i think   i see in NOC parts list.
J.P.
I fit the shims behind the inner next to the crank but I only add shims if the endfloat is above 25 thou or there is evidence the crank is touching the cases on one side. For a low powered engine a ball on the timing side works as an alternative.
Fitting double rollers on any Dommie engine smaller than a 650 is waste of time, money and effort unless you are going racing. Two rollers will also add to the internal friction and certainly rob a 500cc engine of useful power.
There is much to be gained by fitting one good roller and an uprated ball. They make re-assembly much easier and quicker and will almost certainly outlast your ownership of this bike.
On the Timing side go for a a heavy duty ball-race equivalent to the RHP M306. A notched type that employs 10 balls instead of 7 or 8.
Thank you all for your help, i consider all your replies and can now make a decsision .
J.P.
