I hope everybody is fit & well in these difficult times.
After bolting down the barrel in my rebuild I turned the crank but when the pistons were reaching the bottom it became very stiff until they started on there way up again, It appears that I have done something wrong but Im completely baffled at what the problem is.
I would be grateful if someone could give me a clue.
Many thanks Robert
Plastigage will tell all…
Plastigage will tell all. Or a decent internal mike. Or make up a go/no go stick. and check the width to the height.
I don't have the factory…
I don't have the factory spec for the clearance, but I would think one thou would work well . From your replies I don't think you have the necessary experience to rectify the rods yourself. I think your rods are past "fetlling" and need a good engineer to re-size. However sometimes just cleaning and re-building will settle things right. With a regrind and new shells half a thou is enough to give problems.
Lubrication is there. Just…
Lubrication is there. Just no room for it to float the surfaces . Not supposed to touch. I don't think you have the ability to solve it. Find a good engineer. My own crank is still standard but with lots of wear, I fitted some new shells and they came up tight ,so like yours likely to be a thou or two oval. I will also be having a 10 thou grind and am confident that they will be too stiff to use without some re-sizing or a set of new thunder rods. ££££££££ GULP!!
During a recent rebuild I…
During a recent rebuild I found the crank shaft turning a bit tight. The cause was to tight adjustment of the cam chain.
The photos of the shells…
The photos of the shells tells me they are in contact with the crank.
Ok Robert the crank was reground taking 10 thou and I apparently received minus 10 thou shells to fit , so what did I do wrong and more importantly what do I do to make things right?
