Re: 8 inch Full width hub front drum brake on a es2
hello've got a few questions
I have a 8 inch(i guess) full width hub drum brake on my front wheel the brake is mounted on a long road holder and this is on a es2 from 1954 mountet.
1. thus anyone know how much you can turn this drum out? the current size is now 8 inches (203mm)
2. are they called 8 inch brake because they can turn out to max. to 8 inches?
3.can i find this drums as reproduction?
4. is there an alternative how fits on the long road holder forks?
I thank you in advance for your reply
Kind regarts
Romeo Spada
Switzerland
Hello Romeo>
1) The drum can be skimmed slightly to true it back to a perfect circle but not too much as the more you remove the weaker the drum will be and will be more likely to warp again in the future. If you examine the drum carefully I think you can see the edge of the steel drum and it's thickness, something like 3-4mm from memory.
2) Called 8" because the diameter when new is 8"
3) No reproduction brakes ever made....there are many used ones available quite cheaply at around £50-£90
4) Your current full width drum brake is not correct for a 1954 machine....It should have a single sided 8" drum brake....unfortunately these are not so freely available and the price is very much higher at around £200....you will also have to buy the correct brake plate to fit it too for about £100.
You're welcome.
Les
Hallo Romeo>
1) Die Trommel abgeschÃ?pft werden leicht zu wahren, es zu einem perfekten Kreis zurÃ?ck, aber nicht zu viel denn je mehr man entfernen desto schwÃ?cher wird die Trommel sein und wird eher in der Zukunft wieder zu verziehen. Wenn Sie die Trommel sorgfÃ?ltig prÃ?fen, ich glaube, Sie den Rand der Stahltrommel zu sehen und es ist StÃ?rke, so etwas wie 3-4mm aus dem Speicher.
2) Wird aufgerufen, 8 ", da der Durchmesser, wenn neue 8"
3) Keine Wiedergabe Bremsen je gemacht .... es gibt viele benutzten verfÃ?gbar ganz billig bei rund 50- £ 90 £
4) Ihre aktuelle volle Breite Trommelbremse ist fÃ?r eine 1954-Maschine nicht richtig .... Es sollte eine einseitige 8 "Trommelbremse haben .... leider sind diese nicht so frei verfÃ?gbar und der Preis ist sehr viel hÃ?her um ungefÃ?hr £ 200 .... Sie mÃ?ssen auch die richtige Bremsplatte kaufen es auch fÃ?r etwa £ 100 zu passen.
Bitte.
Les
