Engine plate required.
I'm hoping that someone can assist me in loaning the L.H.S. pillion footrest mounting plate as shown as part no 2105 in the attached copy of the parts book.
I could suffice with a template but would prefer to borrow and return an actual part to fabricate a batch for my WD sidecar Big 4's as this is the only part I'm missing.
regards Ian
wd-big-4-pillion-plate-pdf
Ian
I have a set of what I believe you are looking for.
If you could provide me with dimensions I'll verify.
I'm currently accumulating the last few parts for a 1938 model 18 project I hope to get to work on this winter. Hopefullyyouhave something that could be useful to me. First lets verify these are what you are looking for.
Kevin Robinson
dcp02192-jpg
Hi Kevin,
Thanks for the response. I don't have the accurate dimensions as I don't have a sample but I have scaled up the illustration to give me an approximate size. The part I am looking for is the pillion footrest support shown as item 2105 in the attachment to my original request. Do you have one of these or are you indicating you have the rear engine/gearbox to frame mounting plates (Part numbers 2103 and 2104 ) as shown in your attachment?
My email is richtsteig1@optusnet.com.au if you want to discuss the parts you are looking for.
regards, Ian
