Timing light
Any recommendations for an ignition timing light for a 12v positive earth system with coils? Thanks..
I use one that can be powered by a separate 12v battery than the vehicles. Been so long since I bought it I doubt it's still made but it still works fine after all these years.
This one should do the trick,  Draper 52616 Xenon Timing Light. which looks like a newer version of the one i bought years ago and still use. All for  £27
It has an inductive pick up so it doesn't matter if your bike in positive or negative earth.
I also power it from a car battery but it can be powered by the bikes own battery. I prefer to use a car battery as clipping the leads to the bikes battery and having the engine/bike jumping about (as they do) when running is a recipe for wires falling off and entanglement.
Thanks for your comments..
Peter,
I bought the one you recommend and it says on the box 'not suitable for motorcycles or positive earth vehicles', (something I can't remember being in the description before I bought it on line) so i didnt use it. I'll connect it to a separate battery and give it a go..
hello I bought a timing light from the Magneto guys easy to use On magnetos or coils and CDI this can be found on E-bay motorcycle parts yours  anna j
The unit that AJD mentioned is a completely different animal to the others mentioned on this thread. The one purchased from Magneto Guys is a static unit specifically intended for Magnetos where you cannot use a battery and lamp across the points as battery and lamp cannot see the difference between closed points and the primary winding of the magneto-hence the specific timing light from Mag Guys using some modern 'electro trickery' can see when the points open. Yes these units are usable on traditional battery/points systems as well but the timing is static. While the strobe lights mentioned here are for dynamic fully advanced type timing. Bear in mind they use a flash tube which has a rev limit and a limited life which gives it a lower rev limit as well but after some time. So they might give a good light at fast tickover, revving up the flash goes out-old flash tube!
PS I sell the Magneto Guys timing light.
Some high end stroboscopic timing lights can show rpm and advance plus other things. You only need to have a TDC mark (or any other mark with known advance). Very useful on the 40M when I want to know advance at different engine speeds. Funny but the inductive pickup is sensitive to direction. But only to turn it around.
I have one BGS 40106 and an EQUUS 590 518. The BGS is easier as you adjust by turning a knob. Shows rpm and switches to advance when you pull the trigger. The EQUUS shows simultaneously rpm and angle, but has up/down buttons. Probably to be one hand operated. I think that you can do with a much cheaper one.
I 'obtained' an ancient Snap-On inductive strobe from a chap's wife who wanted the garage back after her hubby passed-on. It gives rpm, dwell, advance etc. It can be clipped on to the bike battery but I use it from a spare 12v car battery so it doesn't get snagged up around foot pegs etc.
John
