dominator engine square four frame
has anyone ever put this combination  together 58 square four frame 58 dommi 600
Most unlikely.    I presume you are creating a "bobber" style bike. Its the only thing that makes sense of the component mix. Better than leaving the parts to rust, but not for me.
not really what you would call a bobber? ive got to put a bike together for the AMD world finals in Germany this year so just knocking a few ideas around so all comments are appreciated both for and against
Why not? The Huntmaster was an A10 clone and the squariel was originally designed to go into existing frames so why not use another parallel twin instead. At least you should keep the rivet counters busy telling you what parts aren't correct
Go for it.
In reply to by george_farenden
its somthing diferent it was a spare frame and a spare engine so at leased it gives them a new lease of life im looking for a pair of split tanks next or ill make somthing up
...on when Ogri's mate Malcolm built a Norumph..
"God's Teeth, Malcolm...It's got Anstey Links..."
