First Manxman
Greetings from Portland, Oregon!
I have purchased a 1961 Norton Manxman, which I understand is the first Manxman. It has engine number 18-93601 and Shop number 7.
I've been reading the Manxman threads here and on the AccessNorton forum since learning about this bike and have learned a great deal from you all.  I am grateful for your advice and the terrific information shared.
Here’s a link to the AccessNorton forum thread: https://www.accessnorton.com/NortonCommando/first-manxman.26963/
Also attached are a couple of pictures from today, when my friend and I picked up the bike from the local shipping company.
I'm sure that I will have lots of questions and I'm also hoping to post a video log of the rebuild and stay actively engaged.
As you will see from the pictures, it's going to need some attention, but I'm really looking forward to working on it in the near future.. once I get a couple of friend's bikes out of the garage!
I am looking forward to connecting with other Manxman members
Best wishes
Happy Sunday everyone!
Thought you might like to see the latest vid on the Manxman.  This video covers the serial numbers for the bike, with many thanks to Anna and to Dave, Dale & Mark from the NOC and for their help and the connection to Ken Sprayson. I've also given them a little "shout-out" in the video description. I really appreciate all your advice and support!
https://youtu.be/XPqTAAMIhuM
The project is progressing very well and the video materials are stacking up.  Unfortunately, my day job is getting in the way of all this enjoyment, so progress is a little slower than I'd like, but I'm enjoying it very much.  Upcoming projects include a trip to the strippers! (paint strippers that is), shock absorbers and some really interesting news about silencers and exhaust pipes.
Stay tuned ;)
Best wishes
For those people following the rebuild of this historical bike I can add a few more snippets of detail to its chronology. To begin with.....Mike's bike, like all of the 1960/61 Mk1 Manxman, was built at Bracebridge Street in Birmingham. It was most likely then briefly ridden round the local roads before going into store prior to shipment to the USA, 2 months later.
The 4 bikes immediately preceding, 93597 to 93600, were actually built as ES2 Singles and sold with sidecars attached. The 30 plus bikes before these were almost certainly 99SS models. Most of the latter went into storage and were not delivered to agents for between 6 and 30 months. The records mention about half a dozen of these bikes (from 93581 on) as having twin carb special cylinder heads. For decades there were rumours that these machines had been constructed with proper SS heads. But later dismantled to provide spares to complete batch orders on the 650 lines. If this story sounds familiar checkout the first 50 Commandos built.
In his video Mike displays the engine and gearbox numbers as well as his dating certificate which also records some of the other shop numbers for various parts. In those days major components were built/assembled and stored in in different sections of the factory. The consequence of this being that forks, engine, gearbox and frame would be given shop numbers before going into storage. Then left for months (even years) before being picked at random for assembly into a complete machine. This to some degree explaining why consecutive frames did not always have other parts in numerical order.
For example Mikes Manxman has forks with S/N 901 and Gearbox 19642. The next 650 built used forks S/N 906 and Gearbox 19741.
The BIG question.  If Mike's Norton is the first true Manxman 650.......which was the last???
Hi Philip, Sounds like you have a lot of good information on these bikes.  I am rebuilding a Manxman as well.  I believe mine was built on the same day as Mikes.  I have VIN  93617 on the engine and frame. on the back side, below the left cylinder I have a 20 stamped below the 65.  My gear box is number 20103.  Ive read that there were about 30 built on the first day.
-Pete
Hi Philip,
Thank you very much for posting this.  It’s really interesting!
Regarding the forks with S/N 901, I just looked at the triple trees and noted a couple of numbers from the top and bottom yokes, but I wasn’t sure if this where I should be looking.  Do you know if there would be a stamp or another distinguishable feature that I should be looking for?
Attached are still pictures of the triple trees.  The top yoke is stripped and I can see a cast number of 19018(?).  I still have to remove the paint off the bottom one by hand to avoid damaging the bearing race.
Best wishes
Hi Mike.......I.D. numbers as follows are general and not tablets of stone.
 Norton Dominator - Top Yokes
Wideline                     -  19019  or  L122/174
Slimline                      -  030027
Sidecar                      -  030402 or 21593
 Crown & Stem
Wideline                     -  50259
Slimline                      -  030026
Sidecar                       -  030340  or 21508
It looks to me like the tope yoke (Head Clip) does match the numbers in this table. You may need to remove a little more paint to discover the one on the lower yoke (Crown & Stem)
Attachments show variations of serial stamping positions.
Hi Mike
I watch your U/Tube videos they are great.
I have ridden a 1961 Norton Manxman for the last 10 years.
Pictures of my Manxman can be seen at "The Gathering Of The Nortons" at Washington        Crossing PA.
Thanks for your interest in the Manxman.
  Geoff Craig
Hi Geoff
Thanks very much for your message!  Do you have a link to pictures of your bike by any chance?  It looks like a great event but I couldn't find a Manxman and wasn't sure which year you meant.  It would be great to see pics if you have them
Best wishes
Hi Philip
Thanks very much for sending this additional information.  This is great to know and much appreciated.  I will get back to you as soon as the paint has been removed off the lower yoke (crown and stem)
Best wishes
Hi Peter.......your numbers match my records. As follows are the other numbers as listed.
Job Number 15670
Engine - 93617
Engine Shop Number - 20
Gearbox  - 20103
Dispatch Date - 07/11/60
Destination  - Tozer Berliner USA
Of interest is the Job No which is 18 before that of Mike's bike. Was your bike built before Mike's but did not receive its engine until later? The story goes that the first two production lines of Manxman 650 bikes were held up while engine issues were sorted. There is also evidence suggesting that two bikes were completed and used for road testing the month before full production actually began. That these two machines were given later ID's and then slotted into a later shipment.
Your bike and Mike's headed out of the Bracebridge gate along with 16 other 650 Manxmans. But 28 others had preceded this, including the two test bikes. All of these machines along with another 100 plus were transported up to Liverpool before  shipping over the pond to the States in early January. A second equally large consignment followed at the end of that month.
Some of the second consignment were re-routed to the US West Coast ,Canada and Europe. By the time 280 bikes had been produced they were being shipped all over the world but not the UK. From February onwards a good number of 650 machines headed to Europe but dressed-up in the style of the later 650SS. In essence they were standard 99 frames with 650 twin carb engines in them. Some had Blue tanks but many were all Black.
It is interesting to learn little bits of history here and there.  I am not a collector, I restore and customize bikes for a living, but if there is any way I can hold on to this one, I will.  If it didn't have original paint on the frame I would think differently about keeping it.  The fuel tank, oil tank, and tool box are solid as a rock but repainted and rough.  If I can find  decent original painted parts, I am going to build an aluminum manx tank and make it look the part.  Im having a lot of fun with this resurrection so far.  Here is her current state:
Hi guys
Here's a link to the Youtube playlist containing videos relating to this rebuild.  There have been 2-3 videos since the video above featuring the serial numbers.  A couple relate to a trip to a local metal cleaning company, where the parts were baked and chemically dipped.  It was a great experience and the results are terrific.
https://www.youtube.com/playlist?list=PLgDzKiI-i6nbZN5SMvGkILjvK5OYkDoie
Best wishes
