Hi, i am thinking of using a repro Speedo on my es2 to replace my chronometric one because the new bezel i fitted wont stay tight i have loctited it but it still comes loose the old one was cross threaded the thread was damaged so i put it down to that. do you think a repro 0 to 80 mph one would do the job .
Thanks, Baz
The bike is capable (in th…
Hello George, i was just t…
Hello George, i was just thinking of the speed i normally travel around at. nothing near that sort of speed. then again thinking back i read somewhere that it has to have a Speedo capable to match its maximum speed or above so you may be right. Baz
You may not always be the…
You may not always be the owner of the bike Baz! G
Speak to Russell at info@c…
Speak to Russell at info@chronometrics.co.uk He will fix and overhaul chronometrics. Far better to keep the proper one you've got than get some cheap substitute.
No connection, just a very satisfied customer.
Previously Gordon Johnston…
Communication with him isn't easy, often no answerâ?
Fritz
thanks for that Gordon i j…
thanks for that Gordon i just wanted something to replace it for now with a view to having it overhauled at a later date . Baz
Previously George Phillips…
don't know what you mean George . Baz
George. i didn't understand what you meant by the above. Baz
Hi Barry.The Repro Indian…
Hi Barry.The Repro Indian ones are cheap enough...here is a UK postal addressed one...note it has the 30MPH line but many have a 40MPH line which is less authentic. UNFORTUNATELY as far as I know, these speedos all require a different speedo cable as the fitting is different to the original Smiths size. You can get cables to fit however..The one shown includes a cable but I guess the length is to fit a front wheel drive box. You could contact the seller and see if he has a longer cable.....Les
http://www.ebay.co.uk/itm/VINTAGE-SMITHS-BLACK-SPEEDOMETER-BSA-ENFIELD-NORTON-0-80-MPH-With-SPEEDO-CABLE-/162066042030?hash=item25bbe38cae:g:bOYAAOSwe8tXMaEM
PS...if you buy one, make sure you complain if the rim is dented...many are for some reason...Also the rims are not brass coloured as the photo seems to show....they are chrome-like.
PS 120MPH versions are also available at the same price...Hopefully the internal mechanics have been changed to suit or the legal 10% tolerance is likely to be more than way off....
....but for 15 quid (if you buy from India) it will fill the big hole in your headlamp at least......Les
Hello Les. thanks for the…
Hello Les. thanks for the link. yeah that looks the part. i just want to preserve the old Speedo until i can have it overhauled at some stage .it fell apart and dropped down one day. i think i would sooner fit one of those for now stopping the old one getting damaged. i will check the rim is ok and sort the cable length to suit. thanks Baz
Please check around ....yo…
Please check around ....you might find it cheaper.....don't know....didn't spend much time....Good Luck........(still laughing at that reply you did about the web site)....Les
Hi Baz - sorry for the del…
Hi Baz - sorry for the delay. I missed your post.I meant that you yourself may hold your speed down but a later owner may knock the berries out of it so a full range speedo would be more appropriate. Hope this helps. George
Hello Les, that type will…
Hello Les, that type will do for now it looks the part . yeah i still laugh at it myself
Baz.
Hello George. its ok i cou…
Hello George.
its ok i couldn't work out what you meant i understand now
Baz
The bike is capable (in theory) of 82 - ish, so 80 might be a bit lean. From memory I think the original went up to 120 but I could be wrong. G
