Just about to fit a new Primary chain case seal (rubber band) to my 1949 ES2 to see if it will cure the leak at all, I pre fitted the new seal (bought through the NOC shop and it doesn't fit snug around the case, its pretty loose. Is this normal for this seal ?
Thanks in advance.
Mick
Cut the seal,remove enough…
Cut the seal,remove enough to tension it, and put the join at the top in the middle,wire it together. Fit the seal with a coating of RED RUBBER grease to inner and outer case.
