My apols if this comes up twice. Pic 1 shows original broken mag body, pic 2 shows " new" body with bit missing at bottom. Two questions:: 1) should I just leave it as it is - or - 2) if I fix it how shoul I do it. Cheers George - more probes - pic will follow.Attachments
image-jpeg
Pic 2 - hopefully! Attachm…
I would grind that small a…
I would grind that small area back to sound material and fill it with epoxy metal simply to keep the water and grit out.
Are there no better bodies out there though ?
Thanks Richard. As for a b…
Thanks Richard. As for a better one I suppose I don't want to spend more money than I need to. George
Pic 2 - hopefully!Attachments
image-jpeg
