My recently acquired 1956 Dominator 99 is leaking oil from between the cylinder head and the barrel and soon I will have to remove the aluminium head and replace the gasket.
In the meantime I have checked the tightness of the nuts ( cold ) as per the recommended sequence and for the front and centre nuts which are in a deep recess I purchased a long box spanner from RGM which unfortunately is a poor fit and too soft and is of no use. Although I have a comprehensive socket set none of which are slim enough and so far I cannot find on the internet a suitable long slim imperial socket . Can anybody recommend from where I can purchase a good quality imperial long slim o/d socket that will get down into the recesses so that I can confidently torque up the head.
Any advice re., gaskets would also be welcome.
George
try 3/8" drive sockets
I agree...
3/8" drive are much more useful for jobs like this. I don't have a full set of Whit sizes - just the more useful smaller ones. The trusty Snap-on 1/2" ratchet still comes in useful for wheel nuts, gearbox bolts etc.
I prefer 1/2" drive
for the bigger ones like as I mentioned wheel spindle nuts.
My 3/8" drive torque wrench…
My 3/8" drive torque wrench only goes to 40 lb/ft, so I got a 1/2" to 3/8" adaptor so I can use my 1/2" drive torque wrench for higher torque items like engine sprocket nuts. I do wish I had a means of torquing gearbox sprocket nuts to accurate figures
For the three nuts on a heavy twin head (below the exhaust ports, and between the cylinders at the rear), I use a spanner and spring balance
cylinder head taquing down
hello you start in the middle with number 1 head nut 5/16 then 2 to 4 3/8ths on both sides of the head 5 to 7 two under the front fins and one at the back under rear fins last two 8/9 are 5/16 at the front of the head now all 5/16 nuts are 20lb and 3/8 bolts are 30lb box spanners are best for the head nut at the front fit a socket on top to use the torques rench and get you set of crow foot socket in imperial whitworth happy spannerig yours anna j
Removing inner race from D/S 99 crank
I'm rebuilding the bottom end of my 99 engine but have hit a snag with regard removal of the inner roller race from the drive side of the crank. I'm using tyre levers but with no success even after heating the race with a hot air gun. Ideas welcome.
I would grind a slot in the…
I would grind a slot in the bearing using a Dremel or similar and split the race with a chisel. The bearing should be a light drive fit and if necessary I would ease the shaft down for the new bearing.
Inner race now removed
A fellow club member heard of my plight and told me he had the appropriate tool. This comprised of two half moon shaped pieces which bolted together to form a wedge behind the inner race. The two halves were pulled tgether by bolts. Once gripped thus, the second bit of the tool screwed into the two halves, over the end of the crank with a bolt in the centre that could be tightened to draw the whole device off complete with bearing. Brilliant!! Job done!
Nice to have a photograph of…
Nice to have a photograph of it so that we can all make one if ever needed. Along side a rule for scaling would be even better.
Dick
Bearing separator and puller.
Go to the screwfix website and search for
"Bearing separator and puller ".
For £20 it seems good value to me - at that price it isn't worth trying to make one.
George.
When torquing down my cylinder head, I found 1/2" drive sockets too bulky, so I started grinding them down on the outside. Then I had the idea of using 3/8" drive sockets. They are more compact, and fit into a heavyweight Norton twin head. They have ample torque capacity. Problem solved.
In the '80s when I bought the 3/8" drive sockets, lots of people in my classic bike club thought it was a silly idea. A couple of years later, most of them had a 3/8" drive set.....
