Engine Number
I have just acquired a set of 16H crank cases the number stamped on the side is '83782' with no prefix letters,this is followed withthe common '79 x 100' bore and stroke on theright of the engine number.
Can any one tell me the year of manufacture of this engine..?
Thanks Chris
According to the data in Bacon's Book of the Norton it can't be a 16H as the number indicates 1959 but the Model 16H stopped production in'54.Intriguing! BTW - if the initial "8" ie actually an "A" then it could well be 1946 ie A3782. Or of course it could be off an ES2? George
Chris,
83782 is most likely the War Department number, particularly as it relates to a 16H. It would originally have been prefixed with a "W" to indicate this but it is quite possible that the engine has been rebuilt at a military maintenence unit and the replacement crankcase has been restamped without the prefix.
My own WD16H has replacement cases in which the 79x100 has been ommitted..
If so, your (W)83782 would likely belong to contract S2602 which would date it late 1943.
Richard Payne is probably the world expert on these matters with a wealth of detail at his finger tips, I'm sure he'll be along shortly to to put me right and fill in any gaps, particularly if you could specify any internal markings on the case.
Hope this helps,
Pete
Thanks Chris
Hi Chris
The big question here is do you have WD 16H crankcases or 1938 civilian cases? The cases should have casting numbers which will give you the answer. if these are a 5 digit number starting 10xxx then they will be 1938. If the casting numer starts E69xx they are ex WD.
Roy
MyJuly 1937 registered 16H has an engine number early in 74000 series. No prefix in those days. Yours is 10,000 later. I wonder how many a year they made prewar? (Sorry.. Roy posted his mail while I was typing So this says much the same as he)
Thanks Chris
Hi Chris
Has my previous reply resolved your query, if not there are other ways to check. Do your cases hae the timing cover?
Roy
