The Atlas reg 68,eng no 1252257P has been in the family for 20ish years,Bought in Kent as a rough non runner it came with worn twin concentrics and an older dommy? mag. It had older Borrani record rims and some Dunstall rearsets extra chrome and a plastic crate of old spares that included a set of early spigotted barrels (ring any bells anyone?) . I got it going for my son and dimlly remember having the engine out to check mains and fit a new valve guide /decoke. Since then it has been in use as daily transport,classic rides and 4 holidays in the IOM. It always starts and runs well and quiet with lots (too much!) compression ,loads of vibration and a little smoke from one side.It now has a single mono ,RGM manifold and boyer ignition.One cylinder seemed to have a fraction more compression than the other. After many years of meaning to do something, its time.The top is off and I find lots of carbon and oily deposit on both sides ,one ex guide has been moving although the valves are well seated no air leaks.Pistons are plus 10 flat top ,fit well no ring blowby (some red staining below the pins above the flywheel ) Rings look perfect ..Non spigot barrels and head. Bores are unworn but with a single grit scratch down each side that can be felt with a fingernail. No valve seals fitted.We have new old stock ring sets with the 3 piece oil rings.Suspect the oil is getting past valves/one ex guide and possibly the oil rings ,would like to fit compression plate and stop the smoke . Also intend to balance piston weights and knife edge the piston skirts to reduce weight (closer to orrig ) and reduce oil pumping and stiction.What do you think?.
Being lazy, I'd refit the…
Hi David, sadly no 500…
Hi David, sadly no 500 barrels, The ones I do have will go up for sale after I have measured them up , I was thinking of building up a 750 motor for my 99 but parts are now silly money. The Atlas oil rings I thought were sdo one piece are actually 3 piece all firmly stuck together and with the gaps all perfectly lined up!!. I am wondering if I turned the Atlas flywheel round by mistake all those years ago and that's why its such a beast, Don't think they are marked in any way to correct this.The early ones may have been stamped.Oversize Guides used to be availiable,I can get one made. I don't intend to take the motor down any further as we need to ride this bike and I have 2 more challenging jobs , Rudge mains/box and a big bevel Ducati vee twin.The DOHC Works GP I was helping with has gone to Auction, If I were a rich man, la,la,la !!.I would be tempted,11000 rpm and 110 decibels,lovely.
P for Plumstead atlas
Hello well I am doing a Atlas motor up for a friend and I found that Atlas crank are not balanced well so Next stop is Steve Maney Norton engineering for a crank balancing job , yours anna j
I think you are right Anna…
I think you are right Anna.By 1968 the Atlas was on the way out ,and balance was no longer important ,who needs it with rubber mountings?.
Took the head appart today. …
Took the head appart today. One exhaust guide loose in head , the rest ok. No seals fitted,I don't think they were in 1968. Plain spindles with no flats The smoking was caused by the loose guide but the oily chambers could be either the lack of seals or the slight cylinder scoring in the bores.I am thinking of fitting seals to the inlet guides only and new rings .
Here's the questions, Can I…
Here's the questions, Whats the interference fit on the guide?, with a worn head I would think a 5 thou OS guide would be a good average the hole does not wear evenly and a 2 thou OS guide would likely work loose again with the expansion on the exhaust side. Can I fit seals to the inlet guides where none were fitted before?, Will they stay on, Any downside? fast wear? , No flats on spindles?.Downside to fitting a compression plate? Get 20/30 thou turned off the piston tops?.Its a Devil to kick over ,fitted the biggest possible engine sprocket to gear up but I think if anything that should have made it easier to kick over.
According to calculation, if…
According to calculation, if the head is brought to 200C in an oven, and the valve is cold, the gap starting from perfect fit will be about 2 thou on 1/2" diameter. As soon as the guide is as hot as the head, this becomes about 1 thou. So if cold interference is more than 1 thou, they will still need some force to extract when at they are both at +200C. If the interference is as much as 5 thou, then heating (to extract it) by 200C only reduces that interference by 1 thou to 4thou - which must be hardly worth it. So I don't know if the books give a figure (I'm sure mine didn't), but it looks like much more than 2 thou will start to give more problems because you'll need too much force to get it in and get it back out even when hot.
I cannot remember - but do the heat insulation washers have a bottom cup to tend to hold the guides in on shoulders?
Someone here pointed out that compression plates upset push rod geometry.
Re rocker spindles etc - Phil H wrote an essay somewhere in the tech pages here all about those issues...
Why didn't the bigger engines have a decompressor?
Hi David ,the bottom spring…
Hi David ,the bottom spring cups don't hold anything in. I had a loose guide in a Ducati and 2 thou OS did nothing ,I think that's because the hole wears unevenly. Way back I had a similar problem with a loose guide on a Norton and Finished up with a 10 thou OS guide (that's all there was!) and heated the head up hot/froze the guide and it went in with lots of welly., I expected the head to crack ,but it did not.Bet that would have to be drilled out now.Can't find any info on spindles with no flats.The valve geometry looks perfect from the wear marks on the valves, So machining some off the pistons would seem to be a way to reduce comp AND lighten the pistons.Yes a pair of decompressors, perfect.
I do remember I measured…
I do remember I measured mine, making up an alloy bar and turning it down until it was snug to get as good a measurement as I could. Then I turned down the much bigger 850 type guide to the oversize I'd decided on. I'll look up my notes, but someone out there must know what the interference should be? The hole in mine was nice and smooth and round - but too big for the biggest oversize I could buy off the shelf. Also made up the drift as per the book, and used the same tool to extract the other (stiff) one with. No oil seals. Did they arrive with the Commando because of tilted engine resulted in the head not draining so well, or because they pumped a lot more oil up there?
I suspect that the 72…
I suspect that the 72 Commando got the seals because it was time to sort out a problem that had been around since the late 60's! If the guide is loose with a cold head it must be at least a thou or too loose, add that to the 2 thou interfereance needed and that's 3 to 4 thou ,so a 5 seems a good bet. I,m tempted to leave the rings and bore alone , perhaps the oily carbon in the chambers is from the no seal well used inlets and the smoke is from the loose ex guide.
Note that RGM supply +15…
Note that RGM supply +15 thou Colisbro guides. These can be turned down on the O/D to the required oversize to suit your holes once they've been reamed/bored back to round again.
Terry Guy
valve guides
Hello Yes Valve guides From experience I have found that Colsibro Valve guides are the best and best fitted by heating the cylinder head in your kitchen oven but do not let the other half catch you and you need a good wood chopping board to drop the head on to when hot please use good thick leather gloves you will need to heat the head twice first time to get out the old guides and then after a good clean up of the head to fit the new guides by re-heating the head in the oven is the best way and the safest way it was OK for me to use my oven as I live on my own NO other half to contend with, Ps when you in there clean out the oil ways in the cylinder head yours anna j
Being lazy, I'd refit the pistons as they are into the barrels. Maybe a new set of rings, and hone to improve the finish, but I'd sooner put up with those two grit scratches than go to the trouble and considerable expense of a rebore, with all the ensuing uncertainties about running in, nipping up, piston top cracking, etc etc, plus then having your barrel at the next bore size up. Spend the piston money on a holiday!
New big end shells wouldn't go amiss.
I've no idea how important perfectly evenly weight pistons are on a parallel twin. Everyone seems to think it's important, but surely the only issue might be a small rocking couple? ...which is nothing compared with the inherent primary balance issue with a 360 crank (where either fore-and-aft primary balance or up-and-down primary balance can be matched - but not both).
Can you get a bigger valve guide? I turned down one from an 850 Commando because a loose guide had rattled the hole bigger than the oversize available.
You don't have a rare and (regrettably) valuable 8 fin barrel for a 500, do you?
