It seems my 6 spring clutch on my 31 Model 20 has 2 different sets of springs.
Are these springs the same as the later 3 plate clutch?
I would like to put in 6 new springs
I'm also still looking for an Exhaust rocker arm. My last resort is to cut a new key way in the rocker shaft to reposition the later rocker arm.
Sturmey Archer clutch spings.
Thanks Richard Too bad…
Thanks Richard
Too bad Martin doesn't have E mail. To call from Canada is very expensive.
I'll send a letter to him to this week asking if the springs are still available.
Hi Ian,
I didn't realise you were in Canada and assumed you were in the UK. I guess this makes it more difficult to restore a bike of this age, so re-making the rocker/shaft will be the quickest route to go.
No reply from Martin nor…
No reply from Martin nor billing on my credit card.
Any other sources for the springs.??
Hi Ian,
I will be going to Kempton Park auto-jumble this Saturday (all being well) and Martin is usually there with his general stock. If it is of any help, I could buy the springs and post them to you. At a guess I think this will cost around Can.$21 altogether. You should be able to contact my email through this forum if you're interested.
That's great Richard . Thank…
That's great Richard . Thank you for helping with this !!
PM sent
Ian
Hi Ian,
These 6 spring clutches were made by Sturmey Archer and were fitted to other makes like Brough Superior etc. The 6 springs should all be the same size and are smaller and have less tension individually than the later 3 spring Norton type. Martin Bratby (the carburettor man) makes these and when I bought mine last year they were 90p each, postage will be extra.
Regarding the rocker arm, have you tried putting a wanted ad. in the VMCC journal. I don't think you have to be a member and there are probably more vintage Norton owners than the NOC. The other option is trawling through numerous auto-jumbles!
