Shock absorber
Hello everyone!
it's possible to buy somewhere this rubber?
what do you think? Is it possible to replace?
thanks
those look OK. In terms of fitting them, just slice along the length with a Stanley knife then glue the cut together with superglue when in situ. When I first came across superglue it was used to make up O rings so should be plenty strong enough. Those rubbers are only bump stops so if the springs are correct you should never hit them.
