Norvil side stand useless
I ordered a new side stand for my '55 ES2 from Norvil. I rang them to confirm that it would fit as it was advertised as "stand - side - ES2, 7, 77, pre-featherbed". Mine is a pre-featherbed. I was also told that it required a pin and two circlips as it was wrong to fit it with a bolt. This is despite the fact that the Norton parts list for that year show a nut and bolt as the retaining method. I ordered the stand, pin and circlips which duly arrived a few days later. It took four hours of fettling to fit the stand. I had to drill a larger hole in the lug on the frame bracket and fit shim washers to reduce the free play on the stand as the gap between the lugs was too great but what got me was that when the bike was leaned on the newly fitted stand it would have fallen over had I not been holding it. This was because the stand pointed too far forward owing to the poor design of the top end lug. So all in all a waste of £60 odd. No doubt I can do something to make it work but don't be fooled into thinking that it is a direct replacement. It's not. It's a cheap imitation. George
You should have used the NOC spares....catalog says they have one:
E2/1014 Side stand assembly Bolt on front engine plate type New ....12 in stock.... £102.95
Laughing...Hooray....the Smileys are back......Cool
Les
That's not helpful, Les! ð I knew NOC had one but in a vain effort to save money thought that the Norvil sounded good at half the price. You get what you pay for!! Nevertheless, it should have been fit for purpose which it was not. George
I hadn't realised you were trying to save money (no problem with that I always do....try that is).... I just thought you had overlooked the fact that the NOC had them...that's all.....Frown...Perhaps the 60 quid might seem peanuts when your bike falls over and smashes things up a bit so maybe Norvil will give you some credit on it if you haggle with them and return it saying "it's not fit for purpose".... then buy the real one....but at least you've helped other potential buyers by pointing this out....see yourself as a self sacrificing hero George.....
Bottom line...I WAS trying to be helpful...Embarassed
Les
I've made an entry as to pull this thread back up to the top to enable some continuity....Les
Hi guys - sorry to have caused confusion amongst the ranks! I separated my Norvil saga from my stand query in an attempt to simplify the threads. It seems to have backfired on me! After my guy had offered to make one for £50 I found that Norvil did one for around the same money so, thinking the Norvil one was a direct replacement and would look better, I took that route. It didn't fit properly and took four hours of fettling then wouldn't hold the bike up. I emailed Norvil who, to be fair, answered within the hour noting that I had bought only the stand, not the stand and bracket. They also noted that they had fitted hundreds with no problem. They (or Les of Norvil) asked for some angles to be measured and sent to him and he would check the drawings on Monday. In doing more checking I found that my bracket did not match the bracket on the parts list. Mine is long and thin and fitted to the down tube/crankcase bolts whilst the pic in the parts list shows a squarish bracket fitted to the lower front of the crankcase. The parts list also shows different engine brackets to the ones fitted to my m/c. Hence my current quandary. It may be that I have the wrong bracket and the wrong plates and it's not Norvil's fault at all. But I need to know if the plates are interchangeable - hence my new thread. Whew! George
George, it seems our recent experiences of buying from Norvil have been not entirely dissimilar ... A lot of ifs and buts involved, anyway. I hope you get it sorted!
Neil, it wasn't I who said "pre-featherbed". That was the description in Norvil's listing. I rang them and queried that it would fit a '55 ES2 and was told "yes". But as I say, I may have the wrong bracket. We'll wait and see. George
Update on the Norvil stand saga. I emailed Les at Norvil on Sunday evening attaching a pic of the bracket on the bike and giving the angles he had asked for. He replied on Tuesday (today) morning noting that the bracket was the wrong one for that bike. Apparently I have the bracket for a solid frame machine hence the new stand leg not sitting correctly when down. I now have to decide whether to fit a stand leg that will suit the existing bracket or change the bracket to suit the new stand leg - which I believe means stripping all the primary side down. Anyway the bottom line is that it is NOT Norvil's fault. The stand they sold me is correct. I take it all back! And they have responded quite swiftly.
Hi George
Have a look at pictures of ES2 (ebay ect ) and find one with with the later large engine plates...
I cant find one mine is swinging arm 1954 and has the so called rigid frame engine plates..
Fair comment Barry. Still waiting to hear from Norvil so's I can decide on the way forward.
It seems that my bike is fitted with the incorrect (or its year) engine plates. This means it will accept the E2/1014 bracket but that is the wrong stand assembly for a swinging arm model. It should be E4/1016 which means I'll have to change the plates (presumably?). which in turn means all the primary side off. And this just after I get all the clutch/gear change sorted! Does anyone know if the E4/1016 bracket (the squarish shaped on that fits "under" the crankcase) will mate up with the engine plates E2/522? George
Hi George, not sure why you would need to disturb the primary cases in order to change the front engine plates. Maybe I'm missing something? It might be simpler just to leave the plates and stand bracket as they are, and go back to the idea of having a replacement leg made by your engineer friend.
Cheers, Ian McD
I think you may be right about the plates, Ian, but I believe that the proper bracket fits under the crankcase behind the p/chain-case?George
it has to much travel forwards and not enough backwards then you think it would fit same as in the photo, slightly exaggerated.
stand-jpg
Here's a pic of the "under cradle" stand on my 1956 19S. The bracket can be fitted with the primary cases in situ but you may need longer studs through the cradle. I rarely use it - while it supports the bike at a reasonable angle of lean the foot is too close to the centre line and the centre of gravity seems to be outboard of the foot. This tends to lift the front wheel, especially if there is any luggage carried. Just too unstable for my liking. I have considered having a custom leg made - longer and with a bend so that the foot lands further from the bike while retaining the lean angle. The spring in the pic is not correct, there should not be any coils where it passes the pivot.
19s-side-stand-jpg
Blimey Ian! That bracket looks like neither of the ones I've been looking at! Nice pic, Barry. You'll have to let me know how you do that! That's very much how mine comes to rest except that it's forward f the crank-case. BTW Ian, when I say "under" the crankcase what I mean is that the one meant for my model sits on the side of the crank case just behind the p/chain case and it's squarish. George
All the sidestands I've seen fitted to pre-featherbed swinging arm models bolt to the front engine plates. It does seem to be a hornets nest. Think I'll soldier on without one!
Ian G
Further update. I've heard from Norvil to the effect that the bracket I have on my bike (which is like loads of ES2's that I've seen) is incorrect. It is meant for a solid frame (mod 19?). I've ordered the "correct" bracket (another £50 + ) so hope it will all go together OK. The bracket I've ordered is the equivalent of part no. E4/1016. More anon. George
The 2 styles of front plate mounted stands are illustrated in the '56 spares list, Plate JX rigid, Plate JY sprung. But when it gets to part numbers it doesn't seem to distinguish between the two. As you mentioned previously George the engine plates are also different for the 2 versions with noticeable changes in shape and number of holes so you might not be out of the woods yet.
The below cradle version that I have is not illustrated. I am sure that it is an original fitment as there is an identical one on a frame I picked up many years ago as a spare. Both frames are date coded for '56. I briefly wondered if mine could be a '57 part but then remembered that from '57 the cradle is tubular so the bracket would not work on that frame.
As usual more questions than answers!
Hi, i have just breezed through the posts quickly, i have a 1953 ES2 and the side stand is bolted to the side stand bracket which goes through the front engine plate lugs . The primary case is well out the way .
Andrew
George,
The attached photos show side stands for a 1955 ES2 and approx 1954 Model 7, both from single down tube models, before the change in 1956 or 57.
ES2 casting numbers: bracket 14821, leg 14786 (not easy to read this one).
Model 7 casting numbers: bracket 14787, leg 14786.
The legs are identical on both of these.
In the Spare Parts List for 1955 Models ES2, 19 Rigid Frame and 19 Spring Frame the illustration for frame and fittings (Plate JY) unhelpfully shows a Model 7 frame, which has the wrong engine plates, side stand and petrol tank mountings. Plate JX for the solid frame has the correct picture for the sidestand and bracket, and looks identical to my ES2.
Hope this helps. Regards, Philip
side-stands-es2-model-7-1-jpg
Thanks guys. Philip - the pic you post shows the same bracket as I have (the upper one) which Norvil say is incorrect. According to the parts book they're right but it seems there are a lot of '55 ES2's out there with that bracket. I've checked the bracket and the two legs and can't find any casting numbers on them. It comes to something when you can't trust the manufacturer's parts list! As Ian has noted, the new bracket may not fit the engine plates so the woods are still quite dense. Hopefully Ian, in a couple of weeks or so, you can inspect it all on the Island! George
George,
I'll probably go to the NOC reunion at Laxey but I'll have to hide my BMW Airhead round the corner! Laughing
I'm hoping either to get a lift or take a taxi, Ian. Just in case......... George
George,
Sorry to interrupt your domestic arrangements, but here is a bit more info on ES2 sidestands! I hope I've attached an extract from the 1955 ES2 and 1955 Model 7 parts lists and photos of the sidestand on my ES2. It was a bit dark in the garage to get a better photo this evening, but can take it outside for a deecent picture if that helps.
It's the VMCC Autojumble at the Bath and West Showground on Saturday, so if I see any bits for sidestands I'll buy them if the price is right, then offer them for sale on NOC Classifieds.
Regards, Phil
es2-sidestand-1-jpg
Thanks Phil. The domestic arrangements are a diversion! That pic shows a bracket and stand exactly the same as mine. The parts list did not copy but I already have them anyway. I'm beginning to feel that the '55 parts list is not totally correct but I'll await the arrival of the bracket from Norvil and see how it goes. Many thanks for your input. George
An update. The new bracket arrived today (ordered last Wednesday) but regrettably will not fit the engine plate without drilling which I'm not prepared to do. Have now agreed with Norvil that I'll send them back the new bracket and leg. I've ordered the leg to suit the bracket that's fitted (whether it's right or wrong). The part no. is E2/1014. I would have done that to start with had not Norvil sown the seed that I had the wrong bracket fitted. Anyway, to be fair, they seem to be playing ball so hopefully the leg will arrive later this week and should be fitted before I set off for the Manx GP.
New stand arrived today (ordered last Monday).It was the correct one for the bracket but a bit loose on the lug so required a couple of shimming washers (actually one was a 2p piece drilled out!) Finally got the spring on with the small-coins-in-the-spiral method. All seems well. The bike does not fall over! Fitted my "patent" method for getting the stand to stick out a bit more at rest for ease of access. I fitted a jubilee clip round the leg at the same distance from the fulcrum as the lower engine bolt so that the clip screw impinges on the nut. So anyone with a '55 ES2 should check the stand and bracket before renewing as they do not match the plate in the parts manual. This was the cause of all my probs. Norvil have played ball so far but I'll have to wait to see what rebate I get. George
Hello Kawasaki ZZR600 sides stand very useful costs £19.98pence and my time a brain power to adapt the zzrsidestandto fit my Manxman slimline frame And It's Better than to original it does not slip around the frame tube has I made a plate to fit behindthe crankcase to pick up the two 3/8ths engine studs and then it has a U clamp for the frame bottom tube of the frame mounted in rubber hand made parts and it looks good it's in chrome plate and works really well too , SO NorVil can keep their expensive bit of steel yours anna j
Great news George!
Perhaps you can have the webmaster change the title of this thread? Seems like this one wasn't their fault & they have been accommodating to resolve the issue?
ATB,
Skip
A very fair point, Skip. I tried some time ago when I realised it wasn't quite as clear cut as I originally thought but got no response to my email. I openly apologise to Norvil for jumping to that conclusion but to be fair I had actually phoned them and asked if it would fit before I ordered it. George
As Anna has suggested..make your own. There are lots which can be adapted for £30 tops. They can even look fairly original if you chose wisely.
I made a rear stand like the old Mz bikes had. It worked well but I gad to remive it due to issues with the speedo drive. Totally unoriginal but I did not care at the time.
George. If you feel you have gone as far as you can with Nobvil, the cheapest option now is perhaps to have the stand built up a little with weld at the point where it stops against the bracket. You can then file it back to achieve the angle you desire, before having the stand painted. Would that work?
btw, the title of this thread clearly still stands.....
Ian
Great minds etc, Ian. That was the route I was considering. Or, of course, build up the bracket. At least that is steel rather than CI.
The RGM web site contains advice on how to modify their general purpose stand in the above manner.
Hello My advice is to make your own On Ebay you can get nice stainless tube and bits of nice plate or make a visit to a scrapyard and buy off cuts of stainless steel all you then need is a good press drill and and set of broch drills and a good stick welder you can pick up at most auto jumble sales for 25 quid or so or if feeling brave you can buy a good migwelder I havea SIP migmate90 since 1986 and it's still working to this day if there looked after I can weld fresh air has I perfected this many times welding cars and vans with an MIG seam welding is best now you can get attachments so you can now weld alloys and stainless steels and migwire technology is getting better now I use gasless mig wire which works well you also need a good angle grinder and various disc from flipper discs to cuttingdiscs and most of all good measuringtools and a good marker anyone with good common sense can set them selfs up and use these tools with good results but please get your safety gear to wear like good safety glasses and gloves and breathing mask and work clean and tidy and well-ventilated area and think safety first and last and do take you time working do not rush things if feeling frustrated take a break and have a cupper tea and switch on Classic FM nice calmmusic offend helps And I was LUCKY to have left me in a Will An ATLAS Metal Lathe a10" Swing over bed 1936 F10 with tooling and an ATLAS Mill Drill too with tooling which helps me make my own parts when needed So get out there and have fun with it, and forget Expence-nor-vil yours anna j
So George, just pop out and buy yourself a welder, drill press, broch drills (whatever they are) angle grinder, flipper discs? cutting discs and a few feet of stainless steel tube. Teach your self to weld fresh air, or even stainless steel (always a challenge) and crack on.
Better still just lean your bike against a tree. much cheaper optionCool
The addition of a weld on the bracket seems to be the way forward although the tree idea is cheaper!If I bought all the stuff suggested by AJD and it lasted as long as hers I'd then be 108 - so unlikely to get my money's worth! George
Had my local garage add a weld strip to the lower edge of the bracket and also reweld the broken tip of the original stand (it was not cast iron as I had originally thought). After a bit of fettling on the grinder it pointed in the right direction so refitted it all. The weight of the bike caused the re-welded lug to snap off together with the end of the bracket! I'm wondering if they cooled the welds with water causing the metal to go brittle? Any way I now have a broken bracket, a broken original stand and a Norvil stand that doesn't fit. OhGeorge happy day! Have now ordered a NOC stand and bracket and returned the Norvil stand. Let's hope they play ball again. My heading still stands. The Norvil stand does not fit (out of the box) onto the original bracket. It is not a direct replacement.George
Hi again George. I don't find lifting onto the centre stand such an issue as you. I'm wondering if you can't modify it in the way that Japanese bikes work i.e. it's as much a downward push on a lever on the stand as it is an upward lift.
I think our bikes are pretty similar and as you're only one county west, we could meet up sometime and see if your centre stand seems excessively heavy to lift. Mine is fitted with a side stand but it is useless. Maybe I could try getting it modified although I leave most technical matters to my bruv.
I think the prob is more t do with my dodgy back, Chris. But I've found that holding the stand with my left foot, gripping the grab rail with both hands, back straight, legs slightly bent then straighten legs and rise up on toes (very powerful leverage!) does the trick. Kind of you to offer a meet-up but I'm an hour west of Plymouth Our branch (Tamar) does meet at Calstock (just inside Cornish border) on 3rd Saturday (16th this month if you're able to make it. When I was at the Classic TT a week or so back Ian McDougal from NI lifted it onto its centre stand with one arm so the prob is obviously me!
I use a different technique. Pull the handlebars to full left lock, put left hand on grip, put right hand on grab rail. Lift up on grab rail and at the same time, pull back on handlebar grip.
I think we are as far apart as we could be whilst still living in Cornwall and Devon: I'm East Devon, you're West Cornwall. That makes it a bit of a trek. Never mind, we will hopefully meet up some time.
Thanks Chris. Problem may be solved now as the complete stand and bracket assembly arrived from the NOC Shop today (4 working days from order - brilliant!) and is now fitted and working perfectly. So after all the aggro and mis-information from Norvil the NOC came up trumps (if you'll pardon the expression). The bike now leans at a slight yet reasonable angle all is well.Thanks to everyone for the various inputs. George
Just to close this thread (?) I can now report that Norvil did indeed cancel the cost of the final stand which I returned. So the bottom line is:1)The Norvil stand for a '55 ES2 does not fit the original '55 bracket.2) The Norvil bracket for a '55 ES2 does not fit the engine plates/holes without drilling holes.3) The stand/bracket assembly from the NOC shop fitted "out of the box".When you compare the NOC stand with the Norvil stand you can see the discrepancies in the dimensions particularly round the lug area. The Moral - buy from the NOC Shop!
