Battery done for?
My 1972 Combat sat in the garage for about 9 months without so much as a second look from me (I know, tragic). Anyway, last weekend I dusted her down, drained the oil from the sump etc and she fired up fourth kick. Once warm she was ticking like an old clock.
Following a ride on Monday evening, about 30 miles, I decided to check the battery and noticed it was all but dry. I should say it was flat when I dusted the bike down but as the bike's been rewired with modern 'black box' kit it started no problem. I topped the battery up (with tap water) and charged it for 24 hours.
Coming back from the fire station last night (I'm a retained fire fighter) she conked out whilst sat as a traffic light and wasn't so keen to restart until I turned the lights off, at which point she started immediately. Once back in the garage I did the following.
1. Engine off, ignition on, lights off, press horn - loud
2. Engine off, ignition on, lights on, press horn - click
I'm thinking, and hoping, this looks like a duff (through abuse) battery. Would any sparky's agree?
cheers
Dave
No doubt Martyn :)
The main question I have (re horn not working when lights switched on etc) is, does it sound like a done for battery? The multimeter reads lots of Volts....
d
Empty out all battery fluids and dispose of properly, refill with battery acid, recharge, then try again :)
Tap water will have done the battery no good. It's probably not worth messing about as you'll always suspect the battery, just treat yourself to a new one, They're only about 25 quid If you avoid motorcycle dealers and high street motor accessory shops.
I'd forget the wet battery option; it's the 21st. Century now. Go for a sealed AGM type and forget about drying out and topping up. We have discussed before on this forum the even newer lithium iron phosphate types, e.g. Shorai. Recently I have talked about these with Norton owners who are using them and they are very happy.
Many thanks all. I think the dry option makes the most sense and I'll treat the old girl to one, after all, there's no point having fully modern electrics and connecting it all to a cheapo wet battery :)
Thanks for everyone's help!
d
