Hello,
putting my chain case back together, the oil seal was held in place by an extra aluminium disk snap rivetted onto the case. None of the Norton manuals I have make reference to this, nor are there any schematics, other than a reference to Part A100-20993 Retaining cup for washer with 4 rivets, I can find no mention of it anywhere. Does any one else have an arrangement like this or can anyone point my in the right direction. Ally seems a bit too thin in this area to support oil seal so I can see it needs building up, but I think this part may be home made.
img_20180203_105912987-jpg
Hello there, It's been a…
Previously patrick_mullen…
Hello there,
It's been a long time since I last had this chaincase apart but the alloy washer you are holding is not the same as I remember. The one I think I remember is a dished steel washer held on by 4 rivets. It supports the oil seal and normally you don't take this washer/plate off. It is not mentioned in the Maintenance Manual as far as I know.
Maybe someone else is more up to date on doing this
Patrick
Thanks Patrick, it didn't look right but I suspect it is a good effort at a replacement as I can't find the dished washer on the spares site so may end up using it any way. I have a lathe so making a dished version would be an option. I suspect the restriction is clearence between the sprocket and new washer plus rivets. Although I have been a little harsh with my criticism of the previous builder, much of this engine / motorbike is very good and I look forward to stsarting her up. Though once the engine / gearbox is done, the next will be the forks, then wheels, then when the summer comes the paint. After that I will need to find something else to do....
Previously Andrew Wibmer w…
Hello there,
Patrick
I stand corrected, just found one on the spares page, order on the way. Many thanks.
Andrew
This is an image of a spar…
This is an image of a spare I have , exactly as patrick remembered. I have seen another chaincase with where the casting surrounding the oilseal is thicker and square on the inside of the chaincase ?. memories fade here, I remember something different.
GRAHAM
002-jpg
Previously graham_squires…
GRAHAM
thanks Graham, that looks more likely. This is an early so entirely possible that the later one was a better design - thicker.
Iâll Post a pic of mine l…
Iâll Post a pic of mine later, I have a couple of early ones, but am just off to the Bristol show!
Yes thatâs what mine look…
Yes thatâs what mine looks like, I donât think it need to come apart to replace the oil seal although removing the old one might need some heat?
Dan
Previously Dan Field wrote…
Dan
Hello Dan,
hope you had a productive day at Bristol, if you see any styling panels on your travels you have a ready sell here
. Thanks for posting the photos, I will order the correct washer later on, been a while since I had to use proper rivets though.
Andrew
Iâll keep my eyes open fo…
Iâll keep my eyes open for you, Iâve just found a pair for me from my eBay haul! So they do turn up from time to time.
Ive got to change that oil seal myself, Iâll let you know how I get on getting the old one out.
dan
Hello there,
Patrick
