Here is my Navigator ready for an exhibition next weekend in Friedrichshafen , Germany.
Still with the ugly aftermarket seat, found an original one which needs a new cover. Already contacted Leighton?s.
Front mudguard is mounted for the show only, still hits the upper fork shrouds when the fork is compressed. The cutouts between the fork legs are too shallow.
Was able to find a NOS Wipac Ammeter and an early Wipac Ducon switch with both sides chromed and a shorter flick switch for high beam. Made a new simplified wiring loom, bike is converted to 12 volts , has a Boyer ignition. Left knob is lights on /off, right knob has no function. I mounted an ignition switch with key left front under the tank. A 100mph speedo is waiting for his new chrome bezel to be crimped. Therefore the 80 mph speedo is still mounted, it came with the bike.
And I fitted an Ewarts fuel tap with reserve function- no leaks so far..
Very nice - good job.
Hi Uli, That is looking ve…
Hi Uli,
That is looking very tasty. One minor point is that you should fit a clip to the front down tube to hold the speedo cable back to the frame -otherwise it will rub on the front mudguard and damage your paint. I do like your Wipac ammeter - so much more classy than the Lucas one. Has your fuel tap got two plungers?
What reference number is on your 80mph speedo -it may be from an early Jubilee ? I am looking for an original 80mph one for a March 1959 Jubilee- the reference number I want is SN 3103/20.
Patrick.
Patrick, Yes the tap has t…
Patrick,
Yes the tap has two plungers, with reserve.
The speedo has number SN 3159/39 1760.
So not correct .
Ulrich, Well done. A reall…
Ulrich,
Well done. A really good job. It is not generally known that the front mudguard changed part number in around 1963/4 when Norton introduced wider roadholder forks. Up from 7 ins wide to 7 3/8 ins I believe. Owners have found, like yourself that the later front mudguard scrapes the inside of the fork shrouds when fitted to 7 ins forks. The difference is small.
The earlier front mudguard, on the other hand, can be made to fit both narrow and wider roadholders, but does preclude the fitting of wide front tyres as fitted on some post '63 heavyweights. Like the scrambler look favoured in the USA.
Perhaps reshaping the mudguard or the U bracket will get you the small clearance between mudguard and fork shrouds that you need. Some owners resort to gaiters.
Peter, I bought the front…
Peter,
I bought the front mudguard from Ebay UK and gave it to my painter. This how it looked after cleaning up for painting. The indents were heavily rusted covered with filler. Then they formed new ones and welded them in. Befroe painting I tesed the mudguard in the forks . The upper fork shrouds were not mounted because they were also at the paintshop. I only had the lower frok parts for comparison and gave my OK for paint. That?s hiow the drama started. After the show new indents will be formed and the mudguard will be painted new.
Looking fabulous Ulrich, w…
Looking fabulous Ulrich, well done! Does the fuel tap have a reserve position and if so can you tell us where it can be purchased from?
Nick
Looks lovely Uli, I must a…
Looks lovely Uli, I must admit that your seat looks much higher at the back than mine, although mine is stepped.
I bought one of those taps from my local supplier (CMS Exeter), a Chinese copynodoubt! but they are available - you pull one for on and then the other for reserve.There's one on here not sure about thread size. https://www.feked.com/carbs-fuel/fuel-taps/page-3/
Dan
Previously Nick Clarke wro…
Nick
The tap came also from Ebay UK. It?s an original Ewarts tap, I fitted new plungers an corks. It has a reserve function by pulling out the second plunger.
I had to cut a larger thread into the tank (1/4")because the original tap only had one plunger (on/off) an no reserve. This tap was originally fitted to BSA?s and Triumph?s I guess.
I wanted a period look and no new fuel tap.
Thanks Uli and Dan, I stil…
Thanks Uli and Dan, I still have the fuel tap the bike came with which I think is original because it is the same as my very late model 'F' registered Jubilee I owned back in the late 70s. It has a single plunger which turns to select the reserve but I am struggling to replace the cork to make a fuel tight seal so using a NOC one at the moment which doesn't have a reserve which is rather frustrating!
Nick
The standard Jubilee/Navig…
The standard Jubilee/Navigator petrol tap has a 1/8" BSP thread and it seems pretty difficult to get a tap of this size with a reserve. One of my lightweights has a 1/8" reserve tap and this has what I thought was the more common type with a lever action. (I think it is an Enots) But you then forget which position of the lever is reserve so you still run out of petrol. I have never seen one before with the two plungers !!.
German logic would say that you pull the outside plunger out for normal ON and then push the inside one out for Reserve ON.
Her are some pics from our…
Her are some pics from our "Stammtisch" exhibition at the Motorworld Classic in Friedrichshafen, Bodensee(Lake Constance) this weekend.We can exhibit our classic english and italian bikes in front of the Ace Cafe, which is a real cafe .
Today during some quick test rides on the drive way between the exhibition halls before uploading my bike I saw this VW T1 bus from the firebrigade of the porcelain factory of the town where I grew up! Some 450 km away. The bus is in original condition never restored but I did?nt had the 69.000 Euros at hand to buy it.
Lovely pictures. I vote th…
Lovely pictures. I vote the Navigator as the best looker of all the British bikes on the stand. I wonder who owns it??
The VW T1 (that is the original split screen one) is very much in demand but 69000 Euro is definitely too much. I remember a local fruit farmer here had a new pick-up version way back in about 1957 or 1958; it looked so modern then but I think the early versions had a very small engine - 1200 CCM I think
Previously Ulrich Hoffmann…
Excellent re-build Ulrich,…
Excellent re-build Ulrich,hope mine turns out as well.
