Hello All,
The mechanical equivalent to a carry on film that is my Navigator project continues. I have the kickstart spring back on (another one--it had bent). So far it has proved able to turn the engine over, slip the clutch and all sorts--without breaking anything--and return.
My autojumble kickstart is managing to cling on the splines (I'll be trying to kick it over with the plugs in next!).
And--(after several attempts) have got the primary side in without the key driving the front sprocket pushing out and grating on the case.
I have seen a lively discussion on the right size for the footrest spacers. I my own hexagon rod for the footrests to sit on and made it too long. (I had toyed with fitting a side stand on there)--I may well have it sticking out under the timing side with an extra spacer on it.
The drive side spacer seems to want to be about 4mm shorter than the 2 1/4 inch. My side stand misses the exhaust and my home made (I buy the cones and a friend welds them up) stainless silencers (I have them on all the bikes).
But-- my autojumble kickstart will not clear the silencer.
The felt pen marks on the timing side picture show how much it hits by. I do not think it is the right kickstart as even it if the spacer were the minimum it could be without hitting the frame--it would be nearly as bad.
It will not let me name the files but you can see the situation.
The only way I can see to get round it is to get another kick-start or forge a kink into this one. I think the lever came from a Matchless/AJS lightweight.
All suggestion/virtual tea and sympathy gratefully accepted
JPA
Attachments IMG_5194.JPG IMG_5195.JPG tecJohn, I had the same fitti…
John,
I had the same fitting issue with the right hand pipe. I ordered them from Armours and returned the right one because of a loose fit in the head. The replacement pipe was no better so I used it. The pipes are generic ones for all Norton lightweights. They have a large mounting hole for the footrest bar. The hole is bigger than the diameter of the spacers. The 350 engine is slightly higher than the 250 variant. So one size fits all- more or less. I bought some very large washers and drilled the inner holes to fit over the hexagon rod, shortened the spacers, so I could sandwich the exhaust mounting tabs between these washers. I had no issue with the kickstart arm to hit the (original) mufflers so far.
Here are the measurements for the spacers in inches ordered from the NOC spares before shortening them:
Hello John, You are making…
Hello John,
You are making good progress; it is recognisably a lightweight Norton in your pictures and your problems with the exhausts are well known to everyone who has ever put an exhaust on a Lightweight. Original pipes, original silencers, original spacers with original kickstarts generally fit without much aggravation but the moment you get a non-original part the fun starts. Every little bit can be 'out' and everything just has to be fettled accordingly.
Your silencers look a bit low to me which at least means your rear brake seems to clear but they might ground if you bank it over very far on a bumpy corner.
You may have to bend the right hand pipe to get a better line. Yes some suppliers say that the 250 and the 350 pipes are the same - (they are not)- but the difference is the extra half inch height of the Navigator barrel. Generally it can be forced to fit. You can flare out the pipe with a ball-pein hammer to get it a better fit in the exhaust port. But do it gently.
Your kickstart doesn't have enough offset as far as I can see but otherwise it looks the part. You really need an acetylene torch to heat it up and re-shape. Original norton ones are few and far between.
Anyway. Keep on with the good work. It will soon be firing-up the motor time.
Patrick
My exhausts are a loose fi…
My exhausts are a loose fit in the cylinderhead, I got round this by wrapping aluminium foil tape around the neck of the exhaust pipe tailored to be a nice interference fit,completely inconspicuous. The tape can be removed and the proccess replicated every time the exhaust is refitted. Got it off to a fine art now.
GRAHAM
Previously Ulrich Hoffmann…
Previously Ulrich Hoffmann wrote:
John,
Thanks Uli,
My RH pipe seems to stick out at an angle which makes the Kickstart problem worse. I do not know if the kickstart is the right type and I suspect it will need altering as will the pipe--as to how--that's another matter.
JPA
Previously patrick_mullen…
Hello John,
Patrick
Thanks Patrick,
Have you experience of bending an exhaust?--I have never needed to. The RH one appears to kick out making the kickstart problem worse but-- the problem may be the bend nearest the exhaust port. While I am fitting non-standard silencers--the root cause seems the ill fitting nature of the RH pipe
I have access to gas bottles and will probably be able to alter the kickstart--how much depends of course on the exhaust pipe.
The silencers are low--but--with where the bracket on the exhaust pipe is I can get them much higher--I have a Triumph with a similar measurement and have had no problems (this could be a reflection on my more pedestrian riding these days!).
JPA
Hi john, I have never had…
Hi john,
I have never had to re-shape a normal Jubilee or Navigator exhaust pipe. I got a set of Navigator pipes quite a few years ago from a firm in the Midlands. These pipes fitted my Navigator perfectly. I believe that this firm has either changed owners or the original owners simply ceased as more recent reports gave a VERY bad opinion of a business with a remarkably similar name- it was something like Classic British Bikes. The original owner actually had a Navigator and used his own bike for the pattern exhaust and he actually told me that the Navigator pipes were the 1/2" longer than the Jubilee -so he knew !.
The only effective method I know of re-shaping is by using the acetylene torch to heat the pipe and then gently bend as required. I did this for the pipes on the Yamton - original Yamaha front pipes cut and bent to fit the Jubilee frame and Jubilee stub pipes welded in to fit the original Norton silencers in the original position. But I did the shaping and welding before getting them re-chromed and I think they look "proper factory" . Obviously you will damage your chrome if you do try heating. I have never successfully re-shaped pipes without heat. I have tried wedging a pipe in the branch of a big tree in the garden but it didn't work. You really need proper pipe bending equipment for cold bending and even then it possibly will damage the chrome.
Patrick
Somewhere in the ether my…
Somewhere in the ether my post disappeared! anyway, here goes again, my silencer is slightly upswept, and I think this was the norm and looks better that way?
I made my own footrest spacers and kept filing until the kickstart and brake pedal cleared the silencers. I also remember doing that in my youf!
Dan's picture above looks…
Dan's picture above looks right to me. When it is exactly in the right position the silencer only just clears the foot brake pedal when this is pressed down and it also only just clears the brake lever on the back brake plate as well. It is usually this side that gives the most aggravation-the brackets holding the silencer are handed and if you get them on the wrong side the silencer fouls on the brake assembly. Dan's bike is post 1963 so it has a different shaped silencer to the pre 1963 ones and of course each version has brackets with marginally different offsets.
Patrick
I made my exhaust brackets…
I made my exhaust brackets too! And have just spent an hour fitting a new crankcase seal, hopefully this will have ceased my Torrey Canyon impersonation! Will hopefully fire it up tomorrow after the loctite has set.
Hello Patrick and Dan, Tha…
Thanks for your help--a picture is especially welcome. I think I can attain all the desired bits on this side. A picture of the other side would be most welcome.
By mucking about with the spacers I think that--with the kickstart altered--I may be able to get the other side on but--the pipe is massively loose in the head--as people have pointed out though--this can be attended to.
I straightened the bracket on the pipe (out of line) and can--if I really spring it in--get the kickstart to miss (well nearly). I will bend the K/S lever though as I do not want the pipe to be under load all the time.
JPA
Pictures of the right hand…
Pictures of the right hand side of my Navigator. It is the De Luxe but the exhaust is the same as the Standard
Attachments p8220045-jpgand another to show the be…
and another to show the bend in the kickstart lever
Attachments p8220046-jpgand finally the front bend…
Attachments p8220047-jpgPreviously patrick_mullen…
Hello Patrick--thank you very much. My RH pip[e exits at an angle and the kickstart oid wrong. I think I can alter the kickstart to suit--that picture was particularly useful.
JPA
PS
The chain is all on and I can position the LH exhaust where it needs to be.
And there's more
I have noticed that the right hand exhaust is a much worse fit in the head than the other--it really is loose (the left hand one was new from the club. The right hand pipe sticks out at an angle (the see the picture).
I got the pipes--new but with dings in the chrome with the bike--wrapped in brown paper tape.
I think I have seen somewhere that purveyors of exhausts only make one sort to 'fit' both 250s and 350s--is this so?
JPA
