Previously George Phillips…
It's an odd size somethin…
It's an odd size something like 7/32 BSF or BScY (I'll try to find the tap I bought)...My original nuts were rounded off (ouch) so I used a common size nut with a smaller thread hole and tapped this to make four perfectly fitting nuts that you cannot buy anywhere it seems (spent ages looking) ...You suggest you might re-cut the thread on the screw but this will leave it very thin too thin in my opinion. So best to try new fitting nuts or at least make them as I did.
Les
I am describing here the s…
I am describing here the situation I had on my 1957 Dominator a few months ago.
I dealt with CPC Engineering near Redruth by email when I had a problem with my own chain adjusters. They produce a stock adjuster which is 1/4 UNF (28 TPI) which was not the size on my own machine.
I had to drill both of mine out because they had broken off and I tapped them out to 1/4 BSF (26 TPI) and they made me a pair to suit and did a lovely job of it for about £15.00 and I was extremely satisfied.
Hi Richard the type on the…
Hi Richard the type on the early bikes is like this photo:....I have a feeling that your adjusters were the single screw type?:
Attachments M7%20Chain%20Adjuster.JPG- Log in to post comments
Previously les_howard wrot…
Yes of course. Very different. Quite agricultural in fact.
What ...the older ones or…
What ...the older ones or newer type? (in agricultural terms)
The older type are better in my opinion. I've had the newer screw in ones bend under load whereas a screw/bolt under tension is very strong and secure and they are easier to adjust as its easier to get at....and... it's easier to tighten the large spindle nut as it isn't rubbing on the screw adjuster and wearing off the finish.
Les
Les
That's what I meant by agricultural Not only stronger but look like they have been forged by a blacksmith.
I have a original 1955 19S…
I have a original 1955 19S and the rear chain adjuster is similar to Les Howards photo and the threads is 5/16 bscy.
Svein.
The parts list I have for…
The parts list I have for my '61 Model 50 says that the part number is: E3229
An interchange I found says that the thread form is: 1/4-26 CEI
I wouldn't think that Norton made any changes to this part between '55' and '61
Previously svein_marken wr…
Svein.
Partnr:
Rear chain adjuster complete H12/483
Rear chain adjuster bolt only H12/666 5/16"bscy
Rear chain adjuster bolt nut E3223
Rear chain adjuster fork end cap H12/668
This is from Norton Spares Part List for 1955 ES2 19 Spring Frame.
It seems to be panning out…
George These adjusters are…
George
These adjusters are the same as f/b manx and they may be had from
Andy Molnar product code 18255 at GBP 40.00
Arne
George
Arne
Many thanks Arne. I went o…
George, My 1955 ES2 has th…
George,
My 1955 ES2 has the lollipop shape adjusters and the thread is 5/16 bscy. The smaller locking nuts can be bought from autojumbles from some of the nuts and bolts stallholders, you have to look carefully to find them.
As these adjusters are very difficult to find I got my brother to make me a pair for my other 1955 ES2 project. I've tried attaching a photo, so hope it joins this text!
Regards, Philip
Attachments es2-rear-chain-adjuster-1-jpg- Log in to post comments
George Eh well....99% sure…
George
Eh well....99% sure...
I would contact Mr. Molnar and ask him, if they do not fit I'm sure
they can be returned.
Arne
Thanks Arne. That makes se…
Thread size is 9/32 BSF...…
Thread size is 9/32 BSF...not 5/16...well in my case they are and they are are unadulterated or un-modified original parts....bet you find 5/16th too big...............you might find 5/16" sort of fits but then loses its grip which might be why you think the thread has worn....
PS: Anyway.....these are so easy to make from scratch...including the end plate....One fat washer..... one sawn off bolt....a piece of mild steel bent and drilled.....and a dead easy braze together of bolt and washer....I wouldn't entertain the extortionate price of buying ready made ones....but each to their own.........
Fair point, Les. But the p…
Indeed....Stick with 5/16…
Indeed....Stick with 5/16 BScY if you do make some new ones.
If you do....I would file a flat on the bolt that is welded to the the big washer so it sits better on it. Also note that the bolt does not have to have to be welded to the edge of this washer, it lies at the back all the way up to the central hole and does not get in the way when tightened as it lies snugly in the cut out or slot in the swinging arm that takes the spindle.
SIDE POINT: As far as finishing....well you could get them chromed or better still, bright zinc plated. Then again if you get them welded carefully the original zinc finish wont be affected or damaged too much anyway.
For a quick protecting finish on any fresh raw metal you can use a "Galvanising spray"....NOTE: This is NOT a grey spray paint, it is a zinc solution that chemically BONDS to the raw metal supposedly as strongly as proper galvanising! I have used it and it is pretty good...can be bought from SCREWFIX and other places....very cheaply.
Les
Note for Richard Evans - m…
Note for Richard Evans - many thanks for your pointer earlier this year, Richard, for the firm in Redruth. They certainly come across on their emails as friendly and helpful (and they're fairly local). I've now sent one of the adjusters off to them and await a shiny s/s pair to come back . Total cost inc postage £16. Looking forward to being able to adjust the rear chain tension without the aid of a rubber mallet! George
Previously George Phillips wrote:
