I assume this is an early Featherbed item but I've never seen one with this oval cross-section. (More stuff gravitating to my basement in spite of resistance).
technical1-
Lightweight swinging arms…
Without knowing much, I ha…
Without knowing much, I happened to read this a couple of days ago.
http://www.realclassic.co.uk/norton07110500.html
Might be a Nomad swing arm?
That swinging arm is for t…
That swinging arm is for the 500 to 600 Norton Nomads that were built from 1958 to January 1960. It was used with the 1958 Norton ES2 frame and also used Manx rear wheel adjusters.
As you are in the USA this…
As you are in the USA this must have come from these export only bikes as only one Nomad was ever sold in the UK.
Thanks all. One step close…
Thanks all. One step closer to a clean basement.
Lightweight swinging arms are oval, Iâd have to remind myself if they are like yours!
looked again, lightweights donât look like that sorry.
