Dose anyone know if my 1933 600 engine should have a champion 7 spark plug and if I is possible to get a replacement one, and where from, many thanks Jonathan
I have a "Book of the Nort…
Hi Jonathon The champion 7…
Hi Jonathon
The champion 7 spark plug is suitable for side valve engines you need one a bit hotter for a ohv engine ,the best thing to do is fit an adaptor into the plug hole and fit a 14 mm spark plug these can be made from an old two piece spark plug drill out the centre and run a 14 mm tap through it i have done this on my es2 and now use a champion n5 plug
Regards Roger
What's the advantage of g…
What's the advantage of going to all that trouble, Roger, over simply using an NGK B6ES?
Better performance?
George
Previously George Phillips…
Better performance?
George
Yep i like NGK plugs but still have the problem of much larger thread size in my cylinder head. A bit of me likes the originality
I have a "Book of the Norton" covering all models from 1932 and its states " On SV, OHV and camshaft models with 14mm plugs fit a Lodge H1 or H1P or KLG M80." It should be possible to cross reference these to find a Champion equivalent.
George
