I plan to purchase 1963 Norton Slimline and cofused with the engine number which read as 88/105440/P. This is something new to me as owner of Norton Model 7 & Wideline which has different format of numberings.
Also I don't see 122 in this Slimline engine. So can anyone please confirm if the engine is correct? Does the word P exsist starting 1963 onward? Thanks
10500 series is for 1963 m…
You mean to have 88 instea…
You mean to have 88 instead of 122 in the engine is something wrong? Or it is normal to have 88?
Previously Gordon Johnston wrote:
10500 series is for 1963 model year. The engine should be stamped 88 for, oddly enough, an 88. Not sure aboutthe P though - P was the 1959 model year but the lettering was discontinued after R and 1960.
My 99 engine is stamped99C 85787 butthe frame is stamped 14R 85785 - so only the frame number is on both. That makes it a 1960 model year bike though it was registered in December 1959. Hope that helps.
Previously sundarraju_siva…
88/105440/P............This engine was built at the end of 1963. By then, all Norton production was at Plumstead. This is confirmed by the suffix letter 'P' after the number.
The frame should be stamped with122 105440. Early engines from Bracebridge had 122 stamped on the front left of the cases but some later Plumstead built engines had 88 or 88SS.
My 88ss was 1963 and numbe…
My 88ss was 1963 and number begins 88ss not122. Also has a Plumstead 'P'. So your number looks OK.
Thanks David. So what abou…
Thanks David. So what about your frame? It also starts with 88 follow by the engine number and without the letter P? As the bike I see the frame stamped as 88/10544 without the letter P.
Thanks for the information…
Thanks for the information Phil, David & Gordon. Really appreciated.
The frame has 88- and numb…
The frame has 88- and number but it has no SS or P.The engine has 88SS and has /P at the end.I have an old style log book and the numbers are the same.Yours is about 600 before mine.Have fun!
Yes that's was extactly s…
Yes that's was extactly same on the bike I see.
Thank you very much for the confirmation David.
The frame has 88- and number but it has no SS or P. The engine has 88SS and has /P at the end. I have an old style log book and the numbers are the same. Yours is about 600 before mine. Have fun!
