Folks
much like Dave Coopers thread - i removed the timing cover and intermediate pinion came out with cover along with the pesky washer from behind the intermediate gear. I have consequently 'lost' the timing - whats the safest way to proceed or do i just have to take the head off and start from scratch ? Really don't want to if i can help it - the mainshaft pinion mark is at 3 o clock and the camshaft has not been disturbed but the cogs and chains are uncertain. Any ideas ?
Chris
Hi Chris - All was well af…
A small dollop of grease s…
A small dollop of grease sometimes help to temporarily fix things in place. Either sticking the washer to the inner case or to the back of the pinion/sprocket. This also works when trying to get the two front cylinder head nuts and washers onto their respective studs. The grease holding the nuts inside the socket or box spanner thus preventing them from going on the studs crooked or worse still dropping alongside the stud and being impossible to retrieve..
Thanks chaps I've managed…
Thanks chaps
I've managed to get to a safe position on pistons and valves by following jeanettes excellent reply in Davids thread. Carefully turning camshaft until drive side valves all closed and camshaft marking 11 o'clock, then carefully bringing to TDC. next challenge is getting the ruddy worm gear off - i can see ( and have marked ) the timing mark but i want to locktight the intermediate shaft in the case and then set timing more easily. I tried top gear - standing on brake and 18 inch bar on worm nut - no joy ( yes know its a leftie ) - any suggestions ? i don't want to bust anything but the beggars got to come off !
Chris
Use lots of heat on the pi…
Use lots of heat on the pinion. One way to lock the crankshaft is to feed about a foot of thickish (8 mm) rope in through a plug hole, with engine at BDC and then turn the motor forwards until it all locks up. You need to check that this is going to happen on a firing stroke and hang onto the end of the rope.
Phil great advice - the ro…
Phil
great advice - the rope trick worked a treat - worm gear came off without heat just a gentle twist on an 12" T bar and socket once locked up.
Now does anyone know what 28 degrees BTDC is in mm ( for dial guage ) so i can reset the timing without having to remove the primary chain case ? ( It has a RITA ignition system - no magneto and no points/cam/auto advance )
Chris
? Mod 50 is 38 degrees or…
? Mod 50 is 38 degrees or 15/32" (11.88mm)
? ES2 is 38 degrees or 17/32" (13.5mm)
? Mod 88 is 30 degrees or 1/4" (6.35mm)
? Mod 99 is 32 degrees or .307" (7.8mm)
Mod 650 is 32 degrees or .343" (8.69mm)
The Atlas / Commando has the same stroke as the 650 so within reason 28* ought to be 12% less. So close to the 99 measurement at around 0.303" or 7.65mm.
One of the old Roadholders of 3 or 4 years ago has the numbers in it.
One problem is the angle o…
Humble apologies - my shee…
Thanks for all the help tw…
two further qustions :
1. should the timing idler gear pinion shaft be loose / able to rotate ?
2.does it matter which ay up the oil feed hole in the spindle goes ?
I'm minded to loctite the shaft to prevent the whole shooting match coming apart again when i remove the timing cover - is it okay to do this ?
Chris
Generally, the idler shaft…
Generally, the idler shaft is a tight fit in its housing. As long as it does not wobble too much, when setting the chain tensions, the timing cover will hold it in position. You could try loctite but the seal will probably break as soon as the timing cover is fitted.
The oil feed hole in the spindle must face downwards. The pinion gets its lubrication from an oil mist passing through this spindle and dripping onto it. This happens when the pistons descend and set up a bellows effect that helps to lubricate all the moving parts.
Previously Phil Hannam wro…
Ladies & Gentlemen,
I have a 1965 650SS and I am having terrible problems with not being able to get anything other than a weak mixture and I'm coming round to the belief that I have the valve timing out by one tooth. Should the crankshaft pinion have a centre pop mark on the tip of its tooth and the intermediate gear have its centre pop mark in the valley of its tooth? My intermediate gear has a centre pop mark that seems to be on the tip of the tooth so I could go either way whne setting up the valve timing.
If I was one tooth out would that cause the inlet valve to be open for a shorter time and therefore give me less petrol/air mixture per revolution and cause my permanently weak mixture? The carbs are totally standard and jets etc meet all the correct specifications. I have renewed the petrol tap, float and float needle. The main jet needle is currently at position No 4 i.e. the needle should be giving me a rich mixture.
The machine ticks over beautifully but when pulling it hesitates awfully.I am almost demented by my inability to cure the weak mixture - that's why I'm turning to the duration that the inlet valve is open.
Any suggestions would be gratefully received.
Regards,
Peter Bolton
Incorrect Timing can resul…
Incorrect Timing can result in a serious loss of pulling power despite the engine roaring away. Attached photos show timing marks. On the intermediate pinion someone has added some extra dents because the chain tends to cover the originals marks when all the bits are pushed home. I prefer to use a blob of white paint or Typex.
Is your camshaft chain correct with 10 rollers between the sprockert marks?
Attachments Crankshaft%20Pinions.jpg Timing%20Cam%20Chain.bmp www.nortonownPreviously Phil Hannam wro…
Dear Phil,
Thanks for all that information. Please find below a photograph of the crankshaft pinion which has a pop mark clearly visible on the tooth - no problems there. However on the other photo of the intermediate pinion the pop mark does not appear in the valley of the tooth. It is further confused by two scribe marks going from the pop mark to the valleys of the teeth either side.
What really irritates me is that I restored the bike 37 years ago and got it right then but cannot get it right now.
The only reason I had the timing cover off was to have the mag re-wound. I noticed however that the auto advance springs seemed a bit weak. Would that make a difference?
If I was one tooth out that would make a difference of 7.5 degrees on the valve timing - sufficient to reduce my inlet charge of petrol/air to make a big difference I guess.
I'll put a dab of tippex on the relevant teeth and see what happens when I re-assemble. Oh I timed the ignition to 28 degrees instead of 32 BTDC to take account of petrol changes. Perhaps I should go back to 32 degrees?
Regards,
Peter Bolton
Attachments img_2703-jpgPreviously anthony_bolton…
Dear Phil,
Regards,
Peter Bolton
Forgot to attach the intermediate photo.
