1953 colors on a Wideline Domi
Do you know if Norton factory records indicate the colors of the frame, fuel tank, oil tank, battery carrier or tool box, mudguards on a Dominator 88 Wideline 1953?
What were the color choices given to the buyer then?
RenÃ?
They can include mention of colour but it's quite rare. The vast majority were in the standard colour. The only way to find out is to ask !
The 1953 Model 88 was known as the Dominator De Luxe and most were export only to begin with. The attachments are only a guide as shortages of materials, in these years, often resulted in batches of bikes differing from those in other batches. So some parts might be painted instead of plated.
Check the text carefully as there is a mixture of other models info sometimes inserted between the bits you need.
model-88-colours-bmp
