On a run out for about 30 miles. The clutch lever free play increased all of a sudden. the result massive drag. Had to adjust the cable at the gear box adjuster with no free play to get home .
Made full strip of all clutch components. REPLACED
spider (old one had move inward and had been making contact with inner shaft . Identified by milling marks on end face)
new cush rubber
push rod RGM
adjuster on pressure plate
plate with friction liner chain wheel
new cable
I rebuilt all with all adjustments correct . Oil used lucas primary oil
EP90 gear box oil
A road test of a 1/4 mile . Clutch dragged on set off all gears hard to engage big dragging at road junction etc. free play had increased at leaver end. Readjusted to no free play CLUTCH STILL DRAGS CAN THE CABLE CAM LEVER BE A INSIDE THE GEARBOX END COVER
Anthony, from the last upp…
Previously les_howard wrot…
Previously les_howard wrote:
Anthony, from the last upper case sentence on your question, are you asking "Can the problem be the push rod actuation cam lever"?
Well if you are I would say it could be but more likely is that you might not be adjusting the clutch correctly. But just in case here is how to adjust it.
1)Obtain lots of slack on the clutch cable by screwing in the cable adjuster/s
2) Undo the lock nut on the clutch dome push-rod adjuster....then screw the slotted adjuster right in until it butts up to the push rod and stops...then screw back half a turn and then hold this position and tweek up the lock nut.
3) Take up the cable slack with the cable adjusters to leave an 1/8" free movement at the lever....job done.
If clutch is still dragging ....did you oil up the friction and steel plates? If you did this with a generous amount of oil this will cause lots of drag. All you need is a very small film of thin of bicycle oil (3 in 1) So if you did oil them too liberally, wash off all the plates in paraffin, dry them off and reassemble with a very thin smear of thin oil....bet it won't drag then.
Les
thank you for your reply
I have done the adjustment to the book as you describe . with this adjustment first gear can just be selected front brake on. When kick over ,clutch held back to the bar , clutch is clear. put in to gear . and then kick over bike moves forward.
With the adjustment right . I noted the movmet of how far the push rod pushes the dome cover , all plates are free . I would expect more clearance . as the push rod is too short
Hi Anthony....so from what…
Hi Anthony....so from what you say you have not greased the steel and friction plates?...This is important as greasy plates will cause lots of drag.
Also, from the list you have replaced nearly every part with new items. The term "spider" confuses me as we usually use the terms clutch centre or hub and the large outer part is the "basket"...but you have new items for both of these it seems?
The only other thing it might be is that the friction plates are buckled....especially the plain steel ones. Check to see if they are absolutely flat with a steel rule or surface plate any wobble will definitely create drag. Replace with a new set.
The clutch operating cam or lever can wear but after correct adjustment is made the total leverage and movement it makes on the push rod will be still the same. The movement in total is only about 10mm at most...it doesn't need to move much as it just has to hold the pressure back from the the 3 springs. BTW....If you have the wrong springs or have screwed in the 3x screws too much it could be that the springs are becoming coil bound before full release has been made.....this is unlikely though but not impossible....you just need the screw heads flush with the studs.
Another thing to check is to see if the release is lifting squarely.
To do this sit astride the machine (still on centre stand) make sure it's in neutral and then pull in the clutch lever fully and hold it there. Then slowly depress the kickstart lever with your foot and watch to see if the alloy clutch pressure plate spins absolutely true without wobble. If it wobbles you must correct the wobble with the pressure screws but sometimes if it wobbles a lot, a new set of springs will ensure they are all closely matched pressure wise.
Les
I would suggest checking o…
I would suggest checking out the gearbox mainshaft bearings for wear. Any movement of this shaft will let the whole clutch basket shift in or out, when the clutch is operated, instead of the pressure plate lifting. You get a similar effect if the nuts on either end of the mainshaft have come loose.
You can do a rough check by grabbing hold of the basket sprocket and pushing and pulling it. Any movement will indicate worn or loose bits somewhere along the shaft.
Les
just removed the full clut…
just removed the full clutch . stripped . refit the CENTER HUB . nut tighten to 70 ft/lb . all plates checked for run out on a surface plate and dial gauge .
with cover left off , clutch leaver pulled back to bar. kick start slips to clutch. With engine running clutch disengaged . Plates rattle . like my 748 ducati. . that's tells me no binding plates andfree.
I feel the fault is at the other end. To get a half chance to select 1st gear. had to screw in cover adjuster 2 threads off being flush.
next week end project
Hi Tony, Take the clutch o…
Hi Tony, Take the clutch off and inspect the back of the new spider again,any sign of contact and thats your problem. Remove spider measure length with caliper and use bench grinder or lathe to remove 10 thou ,refit spider on its own 70 ftpounds and check with feeler gauge for a gap between spider and sleeve gear shoulder. You may need the proper clutch puller to get it off.
Previously robert_tuck wro…
that was the initial fault…
that was the initial fault. I bet you are right. the old one had sign of milling . and I was going to remove some meat off the new one. thankyou Robert let hope it is a poor made new unit. out with the spanner again
It may not be bad manufact…
It may not be bad manufacture, the orriginal design asks a lot from the engagement of very small shaft spline shoulders and spider ,a bit too much tolerance and a high torque and something has to give. I would use less torque and locktite and a lockwasher that is a close fit to the shaft to provide support to the shoulders . Some spiders have a better design with an uninterupted stop, don't know what they fit though.
Maybe I'm misunderstandin…
Maybe I'm misunderstanding what Robert Tuck is suggesting but I can't see that even if the clutch centre hub (spider) IS touching the sleeve gear slightly why this should create drag from the engine into the gearbox..
The clutch is chain driven from the engine sprocket to the toothed clutch basket, and should be free to spin when the clutch is disengaged, leaving the centre hub spider stationary.
The centre hub spider...(the part you say is causing the dragging) should NOT be revolving anyway if the clutch has disengaged correctly. You seem to be saying that the clutch centre hub (spider) is always revolving and might be rubbing on the end of the sleeve gear (gearbox output shaft) but this is not the case when the clutch is disengaged....
Furthermore if the clutch hub is rubbing it cannot turn the sleeve gear or the main shaft as the sleeve gear carries the gearbox sprocket with the chain to the rear wheel. So, when you are stationary the sleeve gear cannot be casually spun round by a rubbing clutch centre hub or you would be moving forward in neutral under its power....In fact any rubbing will actually hold the clutch centre hub even more stationary and assist in the clutch remaining motionless when the clutch is disengaged which will help in first gear engagement.
Les
Not all clutch pushrods ar…
Not all clutch pushrods are the same length. If this one has been fitted with an inappropriate push rod, it will be near to impossible to adjust correctly.
Hi Les, In practise the cl…
Hi Les, In practise the clutch hub still turns even when the clutch is lifted ,if this turning is transmitted to the sleeve gear effectively the sleeve gear is now locked to the mainshaft. All I know is that giving a clearance changed my clutch to a working one. It is a bit of a mystery to me too as the thoery and practise seem to be at odd's with each other. I also found that replacement plain plates were a fraction too big in diameter and tended to drag on the inside of the basket if tilted very slightly ,wear marks inside the drum are a clue. perhaps Tony should hang loose till the gearbox guru's have kicked this around for a bit!!.
I agree with everything yo…
I agree with everything you say Robert.
Reading Anthony's original question again...(it's easy to stray away from actual details as the thread moves on) the problem started suddenly and was not cured when the clutch was mostly renewed, so maybe the clutch operating lever & roller in the gearbox has broken in some way so although it moves, is not transmitting the full thrust movement to the push rod?
The clutch outer cover is easy enough to remove after the kick-start lever has been removed (gear-lever can stay put....leave in neutral though). I would replace the lever and roller too...don't forget a new gasket when you order.....some oil will be lost too.
Les
PS...I can never get my head around the way the lever pivots on the profile of this lever:
Norton%20Clutch%20Push%20Rod%20
Is there any chance, Antho…
Is there any chance, Anthony, that the gearbox bolt has loosened and the the p/chain is now too tight?I had a lot of probs with an ES2 dragging clutch which were primarily down to a too-tight p/chain. George
George is right, but also…
George is right, but also a chain tight spot will rock the basket and cause drag too.
Is there any chance, Anthony, that the gearbox bolt has loosened and the p/chain is now too tight?I had a lot of probs with an ES2 dragging clutch which were primarily down to a too-tight p/chain. George
Thanks Robert and sorry ab…
Thanks Robert and sorry about the double post. Nothing happened for the first half hour then when I clicked the button again it appeared twice. G
THANK YOU ALL for your tim…
THANK YOU ALL for your time and advice received. it all be mentally logged. The primary chain is at the moment under adjusted for now . I going to strip it again with all your remakes in mined
Les
