Out of coincidence to the recent Wet Sumping message, I have had my own surprising episode of a very wet sump start today. I had left my newly restored M7 for about 2 weeks (I have been very busy and not had the chance to ride it). It was left with a pretty hot oil tank full of 20W-50 oil. Starting it today, I left it to tick-over and was amazed (horrified) that about 1 pint (500ml) pumped out of the breather pipe onto the ground this amount of course doesn't include what the scavenge pump is returning to the tank so total amount must have been something like 600ml. Having owned other Norton twins before I have never known so much oil to drain down over such a short period. So I searched for this topic on this site and found 36 pages on this topic. To my relief there were examples of much worse examples compared to my one. So here is what this message is about.
It would be nice to know what is the average amount of oil that Dominators drain into the sump over a unit time. This would enable owners to judge if their engines was doing what they all do or is their engine much worse or better than average. Unfortunately the oil type makes a difference but generally speaking it going to be 20W-50 or 40 or 50 straight?
So to start the list:
My engine lost 600ml in 2 weeks (20w-50)
It would be nice to be able to get a list made from the reports of other owners and in this way we could get the average for the Heavy Twin engine (including Commandos and engines with a new oil pump fitted)
Hopefully enough details could be compared to get a reasonable average to either put owners mind at ease or alert them that their engine is wet sumping way too much.
Les
PS How to know the quantity?
Well my one pumped it out of the breather, but one could check the level in the tank before starting and then compare the height after the engine scavenge was seen to return to a spasmodic spurting from the initial continuous return flow and do a reasonable quantification.
How long is a piece of str…
Maybe my thread under Sing…
Maybe my thread under Singles - timing chain drip pot - could help here? George
On my SS-engined Wideline…
On my SS-engined Wideline I have a black plastic pot, much bigger than the one you use George, wedged down in the rear engine plates between the oil tank and tool box. The breather pipe, which is from the back of the timing chest, goes in that, with another going from there to the back mudguard. Provided the ends of both pipes always remain higher than any oil which may be in the tank, it works well. It rarely needs emptying. I also have a small breather pipe going from the inlet rocker cover into the catch tank.
The bike gets used quite regularly, but if I was to lay it up for any length of time I would drain the oil tank, just in case.
In answer to the OP's question, I don't know how much it wet sumps!
I agree and appreciate tha…
I agree and appreciate that to get a consistent guide to how much oil drains down in the Dominator engine is difficult mainly because usage and rest periods are so varied apart from the different types of oil owners use.
The reason why I posed this question or idea was I suppose to get some solace by finding out that 1 pint of oil drain over 2 weeks is not that uncommon. However I would still find it interesting to know what the minimum amount of oil drain is possible at best and details of the engine (and Oil type) that is able to to this.
I've been on a warm 120 Mile ride today and have left the engine with pistons at TDC so I'll see if this procedure reduces oil drain as Norvil suggests. ...Thanks for the replies....Les
In all my years as an ES2…
In all my years as an ES2 rider, two off, I have never had any oil out of the breather pipe, If left for a week, or two then the entire contents of the oil tank may empty into the crank case but soon gets pumped up into the tank with no ill effects what so ever. I do however get some out of the left side main bearing as there is no seal there.The type of oil used has sod all affect on the drainage neither does the fact it is TDC or BDC.
I recently read an article in a bike magazine from the 1930's and they were asking the same questions back then. The idiots at the factory only solved the problem on the Mkiii Commando. Not bad really as it only took them seventy odd years to sort the problem!!!!!!
I'm not familiar with mod…
I'm not familiar with model 7 plumbing but on later bikes the breather goes to the oil tank. On mine a slow tickover after firing up sends the excess back to the tank. So maybe your particular problem only the relativelyy small number of the earliest machines?
There was a recent article…
There was a recent article in Roadholder about reconditioning your oil pump to prevent wet-sumping. I don't remember which issue. The gist of it is that if your pump has end-float, or any debris damage, oil will flow through the pump into the sump. You have to lap the pump body so that there is almost no end-float at all, but not a high-friction pump.
Doing this will reduce the problem to a small level. Another approach is to accept the sump-filling, and fit a long breather pipe. When you are about to start the motor, remove the long pipe from your oil collection bottle, and place it in the neck of your oil tank. That way, the crank-case pressure will drive the oil out via the breather pipe, straight into your oil tank. Once it stops, your motor will have warmed up somewhat, and you and the bike will be ready to set off.
You like?
The idea of piping the bre…
The idea of piping the breather, to a catch bottle, may be "eco friendly", but defeats the original intention of lubricating the rear chain. I refer to the early twins, which did not have the breather piped to the oil tank.
Fair point, John, (rear ch…
Fair point, John, (rear chain lube) but must admit my original idea was for the timing side drain. If I leave my ES2 for a week or so I get clouds of white smoke on initial start up. Presumably oil in the sump?
Previously John Shorter wr…
Not so, John. The breather pipe from the oil tank lightly lubricates the rear chain. The breather to catch tank is from the engine.
Sorry, you are wrong. The…
Sorry, you are wrong. The later Dominators may have the system you describe, but, up to, and including, the?54 model, the crankcase breather was a copper tube exiting above the gearbox sprocket.
Hi Chaps I'm not trying t…
Hi Chaps I'm not trying to start an argument here but I think (actually I know) the early Model 7 bikes had the main crankcase breather exit the engine and curve smoothly downwards to point at the ground well in front of the gearbox sprocket. The Oil Tank Breather was a small bore (1/8") copper pipe fitted to the tank with a brass nut and ferrule coupling that was bent carefully around (the houses) to finish just above the chain at the gearbox sprocket end...this tends only to work if the tank is filled quite high.
I have extended the main breather pipe a few inches with a rubber petrol pipe so that when on the move any drips that should emerge don't spray onto the lower frame parts or rear tyre. This new height of the open end above ground is about 2"
Les.
Les, if you want to know w…
Les, if you want to know what level of drain-down is possible 'at best' then my advice would be to fit a new Andover Norton oil pump. They are better than the originals and certainly better than any sixty-year old reconditioned pump.
My experience on a Commando and a friend's on a 16H has been that losses are minimal over a period of weeks and only noticeable over months.
Crankcase venting into the oil tank is a bit horrible really. It results in products of combustion and condensation being delivered to the oil tank with the further problem that if the oil tank has been overfilled, a venturi effect will blow the lot out of the back...
Thanks very much Richard..…
Thanks very much Richard....just taken a look at the A.N. web site and was pleasantly surprised the pumps are available at not too massive a price........so I'm pretty sure I will get one and fit when I take off the timing cover when I adjust the chains. My original pump did show a bit of wear with some very slight tooth damage I obviously lapped in the end plates for zero clearance. The most critical clearance is at the tip of gear teeth relative to the chamber and this is where the static oil route bleeds by mostly but tooth wear creates another route.
I Must say I'm very impressed by the (new?) Andover Norton Web site....for anyone not having looked recently I recommend they do it's really excellent and worth spending some time looking over it.It must be the best motorcycle spares site in the world
Les
Les, I've been down the l…
Les, I've been down the lapping route and to be honest, I wouldn't bother anymore if I didn't have to do it. Prior to the AN pump I used a Nourish pump on the Commando. They were said to be CNC machined and higher spec but it drained down worse than the old standard type.
There were a lot of pattern pumps around in the early 1980s. I think they were Wassell ? They weren't bad and there was nothing else at the time but they were clearly made down to a price and I don't think that the aspect of draining down was a major priority.
I've never seen a Norton pump so bad that it failed to deliver and scavenge but this aspect of static leakage is a blasted nuisance.
Previously George Phillips…
Interesting, if I leave my ES2 for weeks, sometimes it will empty the oil tank completely, other times its just a little, but if I rev it at start up I get blue smoke! I always leave it ticking over until I get the sporadic retrun to the tank and have never had any large quantities of oil out of the breather Dan
John, as you mentioned a c…
John, as you mentioned a catch bottle, which is what I said I have, I then explained that I too have rear chain lube courtesy of the oil tank breather. Mine is a 650SS motor, so clearly not an early twin, as you mentioned. I am not suggesting Les does the same with his, it would spoil the originality.
No Ian, you said the chain…
No Ian, you said the chain was lubricated from the oil tank breather, not from the crankcase. Not so, for the early twins, the crankcase breather blew onto the rear chain. Les?s engine is almost identical with an early 88, but his breather apparently does not extend to the gearbox sprocket.After over 60 years, who knows if it has been modified, or not.
I was talking about my bik…
I was talking about my bike John, not Les's. Mine has the catch tank, ffs. You have got hold of the wrong end of the stick. Let it go.
OOOOPS! Seems that I was w…
OOOOPS!
Seems that I was wrong....Looking unsuccessfully for images of the old breather found nothing but I did find this detail in the user manual.... (click on attachment at bottom of this message)
So for sure the old Dommi engine had the crankcase breather pipe arranged to blow directly on the rear chain....(at what exact point not known by me but probably in front and at mid way on the gearbox sprocket...OR was it just above?)
Thinking back (some years now) I must have smoothed the bend round to discharge vertically rather than have it blow on the chain. It would be easy for me to bend it back to blow on the chain but to be honest I'd rather have it the way it is as I hate the rear of the bike splattered with oil. I have two new chains and swap them at intervals and use the modern spray dry lube after washing the chain in paraffin/petrol, I consider that an oily chain simply picks up road dust and grinds away the sprockets and rollers.
Furthermore the small Oil Tank breather was there just to release the oil scavenge air surplus and no mention of this running to the chain area....No wonder the route looks difficult....
Sorry once again for the wrong assertion I made earlier:
breather-jpg
I'm pulling this slightly…
I'm pulling this slightly off topic but as modern chain lubes weren't around in the 50's what's the view on re-routing the crankcase breather as Les's suggestion? Good thing or bad thing? George
Modern chains still benefi…
Modern chains still benefit from regular oiling, hence Scott oilers!
Since the oil mist must go…
Since the oil mist must go somewhere, why not direct it to where it was originally intended, i.e. the rear chain? PC, and eco friendly, enthusiasts may be horrified, but, how many bikes over 60 years old are ridden regularly for long distances?
It's better to have an oi…
It's better to have an oily chain than a dry one, even in dusty conditions. JG Churchward, a well known engineer in his day, ran trials which involved feeding sand into axleboxes. The dry ones failed very rapidly, the lubricated ones survived. A good enough comparison for me. One drawback withkeeping the back of the bike free of oil is corrosion of the mudguard. One of my bikes has a fully enclosed chaincase so no oil fling and it's rear mudguard has rusted through... One of the reasons classic bikes have survived is the anti-corrosion properties of oil leaks. My Land Rover chassis has survived 60+ years thanks to light oil misting. The odd drip on the shed floor isn't always a bad thing.
Interesting point, Gordon.…
Interesting point, Gordon. BTW - which one of us is "the odd drip on he shed floor"?
No one has mentioned the a…
No one has mentioned the anti drain valve. Mic Hemmings told me the other day he has sold 2000 of them so they must work.
Looking back at your initi…
Looking back at your initial post Les, you say that the bike is newly restored. I wonder if the rubber seal that fits over the nose of the oil pump has been omitted or dislodged when fitting. this would allow oil to drain quickly through the pump and into the timing cover and on into the crankcase.
I have a Mick Hemmings anti drain valve for sale in the classified ads of this site if you are interested
Hi David...please don't f…
Hi David...please don't frighten me to death
I have also wondered that, but if this was the case the big ends would be shot already and the bottom end would be clanking....I would imagine.
If you think about it though, the amount of drainage if the rubber conical washer WAS missing or dislodged wouldn't really increase hardly at all. The oil seepage route has to pass through the pump...it is the pump that controls the rate of drain when idle... so no difference when the seal is there or not...the quantity is due to the condition of the pump. The big end bearings, even if brand new and perfect, amount to a large area of clearance so don't control the drain rate at all.
One quick surefire way to check the rubber seal is to test the oil pump pressure and this could be done quickly from outside by testing at the old oil pressure gauge bolt in the timing case....sadly I don't have the right union but I do have an oil pressure gauge.
It won't be long before I remove the cover to check chain tensions and I reckon I will buy a new pump, sadly though, as so much of my bike/engine is original which pleases me...If you replace things with modern new components, the bike gradually loses it's character I think...
Thanks for your suggestion, I hope you are not right though...
Les
If the seal is split or di…
If the seal is split or dislodged then there is hope, your pump will still pump oil and the flow will swamp the opening to the gallery in the crank. The centripetal forces will drive the oil out to the big ends and the space it leaves will be replaced by more oil, so you will still have flow to the big ends, pressure will be well down though. As long as you have the 6 start worm and pressure feed to the rockers, if you crack open the feed to head at the rocker box then the emerging flow will tell you if there is pressure or not and give an idea if the seal is missing or split.
Hi John, regarding the fli…
Hi John, regarding the fling* of oil out of the big ends. Yes the combination of centrifugal and centripetal force acts like a pump where the oil being flung out of the bearings pulls the oil into and through the big end bearings continuously. I once read somewhere that Triumph engineers had an engine made with a diverter valve so the crankshaft oil supply could be switched to flow directly from the oil tank, bypassing the oil pump. This was switched over at high revs and the engine functioned perfectly well with no wear.
A point of interest: For the same reason, the oil fling can actually lower oil pressure at high revs, as the amount of oil being flung out exceeds that being pumped in. As the pump can only supply a fixed amount proportionately to the revs, the pressure drops. This problem was addressed by Matchless by fitting double capacity oil pumps and with Norton double speed pumps.
Hopefully my oil seal is OK but must either check the oil pressure or take the cover off.
* Not wanting to be too pedantic John, but if you look here it explains the difference between Centrifugal and centripetal.
http://www.diffen.com/difference/Centrifugal_Force_vs_Centripetal_Force
Les
Les I left school many yea…
Les I left school many years ago and have no more exams to take, what something is called is of no consequence as long as it works in an engine
Fair enough John. I too le…
Fair enough John. I too left school many years ago, but if I can achieve or learn something new every day then I am happy and satisfied I have not wasted the privilege of living it....Les
You say that the pump cont…
You say that the pump controls the rate of drainage when idle, a further plug in the bath is the seepage past the big end shells. If your crankshaft nose seal is missing or split then the big end shells will be out-drained by the missing seal. (Some people try and leave the crank in the TDC position when idle to reduce the weepage past the big end. Unless your big end journals were higher than the oil tank, I don't think this is a game changer)
Hi David...I did mention t…
Hi David...I did mention the big end bearings, but I don't think there is much oil restriction here. You have big ends of 1.5" diameter which works out at 4.7" circumference and we have 4 exposed ends giving a line gap of some 19" length of about 1.5 thou. This gap will easily exceed the gap through the oil pump feed gears. Yes it will offer some restriction but oil can creep through virtually any gap and the smallest one is the one that controls the rate....IE the pump....I agree that parking the crank at TDC (which is not that easy as the balance factor always pulls the crank down a bit) won't make hardly any difference but theoretically you have halved the "head" of oil so in theory the rate of flow should be reduced proportionately.
Les
The attachment shows 2 tim…
The attachment shows 2 timing cover gaskets. The light brown one is for a 650 twin and the other mottled grey for a 750 Commando. Both will fit the full range of Heavy twins from 1948 up to the first 850 engines. The big difference, which many people ignore, is the thickness. The Dommi gasket is only 8 thou thick whereas the Commando version is 34 thou. Fit the Commando gasket to a Model 7 engine and you can immediately lose up to 24 thou of pressure on the conical oil pump seal. Though these seals were, at one time, available in two thicknesses.
With regard to wet-sumping, the suggestion of leaving the crankshaft positioned at TDC helps as a temporary fix, but is not a good idea for long term storage. That statement should get this thread lively!!!
Adding a little more to the wet-sumping comments, a good many owners of 961s (but not all) have had anti-drain valves fitted in their plumbing in order to solve a similar disappearing oil issue. Is this a quality control problem???
timing-cover-gasket-jpg
The Commando gasket will b…
The Commando gasket will be a lot thinner by the time it is clamped up though Phil. Being some sort of rubber, the oil pump seal should cope with varying degrees of pressure, one would have thought. It shouldn't take too much to seal it.
As for the 961 wet-sumping, who now says it is not a proper Norton?
Hi Phil...thanks for the i…
Hi Phil...thanks for the info...Just to add, and as you will know, the old 500 engine doesn't use a gasket behind the pump (metal to metal) so a thin timing cover gasket is used. The later bikes? and Commando do use a gasket at the pump to case joint so they use a thicker timing cover gasket to space it out to match...always best to fit the cover without jointing goo tighten the screws slightly and then remove straight away to see if the conical rubber seal is being squashed sufficiently by looking for witness marks....you might then, if money is no object, fit another new one before the final cover fit
Les
I have been able to quanti…
I have been able to quantify the wet sumping on my 650SS. Due to a broken exhaust pushrod needing to be replaced, I have had my timing cover off for retiming. Due to other work, I have only just refitted the timing cover after one month. In this time only 85mL of oil drained through the pump into the collection container below the pump. So my engine wet sumps less than 4mL of oil per day. Oil used is Penrite HPR 50 (SAE 40 - 70 multigrade)
Hope this helps.
Thanks very much Ian for y…
Thanks very much Ian for your reply....interesting...so less than one teaspoon per day. I note that the oil you use is pretty heavy stuff and this will reduce the drainage compared to the 20W-50 that I am using. The other factor of course is that your oil is draining when cold... so one has to assume when your engine is stopped after a lengthy run with hot oil, the initial drainage for at least an hour or more is a bit more, until the oil is cold again and thicker.
Yesterday I started my engine after a week of non-use after the sump was cleared and the engine stopped. This entire period was with cold oil and although unable to measure it (it was dumped on the ground) I reckon it was more than half a mugful so considerably more than 4mL per day. This amount seems excessive so I have decided not to use the bike until everything has been checked and a new oil pump fitted. One thing that could be a cause is that the oil pump is loose on its two stud fixing (nuts are loose) allowing drainage past the rear of the pump directly from the oil tank, this will be the first thing to check.
Just some extra thoughts regarding oil being pumped from the breather:
As you know, the 4x breather holes in the camshaft are set radially round a larger diameter central boss designed to centrifuge oil off the camshaft. This central boss is also protected or screened by a tunnel cast into the engine crankcase to stop the direct impingement from the oil fling off the flywheel*. It occurred to me that one should perhaps not let the engine tick-over when starting with a wet sump but instead, rev the engine a little in order to spin the camshaft faster so oil would be flung off and away from the camshaft breather holes and the sump would also be scavenged to an empty state that much more quickly too, all helping to avoid oil pumping out from the breather pipe.
SO....I tried the theory.....but guess what...all that happened was that oil pumped out of the breather even faster
...This just does not make sense.... well maybe it does in that too much oil in the sump overwhelms the camshaft in a massive deluge that centrifugal force can't fling off......
Will update again when things are fixed...
....noting that it might be quite some time
* Also note the camshaft runs in an oil bath trough that is filled mostly by oil fling although some of it is by the head drainage into it via the tappet tunnels.
Just as a point of interes…
Just as a point of interest my ES2 sometimes wet sumps more badly than others, on one occasion after about a month of siting idle, the oil tank was almost empty, I started it and let it tick over, all the oil returned to the tank and not a drop came out of a breather.
If I knew that my bike was…
If I knew that my bike was going to pump oil out of the breather all over the floor after standing for a while, I would do one of two things; either drain the lion's share of the oil out of the sump drain plug before starting; or if I knew it was going to be laid up for a while, drain the oil tank after the last run. Either would probably take less time than mopping the mess up off the garage floor/drive/road, not to mention the unsightly stains which are left, incurring the wrath of swmbo....
Hi Dan,...I've had other…
Hi Dan,...I've had other Norton Twins and they didn't throw oil out from the breather, the engine just gradually emptied the sump and that was that....I am wondering if the problem is being caused by the newer version of the timed breather disc being fitted, (see recent thread on this) maybe the timing was changed by Norton when the breather pipe run was changed to run back to the oil tank but it doesn't work too well with the old short breather pipe?...This is so annoying I would never have accepted the revised disc if I had known, but I was told this was an improvement!
Fortunately when the sump has been emptied I don't get any more oil blown out on a run so in future, as long as I can keep the wet sumping low, the problem shouldn't be so bad and at best create no problem at all.
You're right Ian, but I have only just started to experience the problem due to less usage and have been caught out several times now.. The last time I tried to start it I put down some rag to catch a "few drops" but it flooded out, saturating the rag and gushed all over the garage floor not seen by me as I was on the RHS of the bike.
I'll see what happens with a new pump fitted and thicker oil in the tank.
Cheers All....Les
Just checked my ES2's sum…
Just checked my ES2's sump after about a 10 day lay off (I think!) and got around 560ml or about 1 pint in the sump.This is using Comma Classic motor oil 20W/50. No idea whether this is normal but it sounds about the same as Les's. George
Thanks very much George. T…
Thanks very much George. This is what I in my original question was requesting....specific quantities over specific time periods vs oil type and viscocity. So in your case with multigrade 20W-50 (the same as me) drains roughly at a rate of 2.3ml per hour that's about half a teaspoon, which doesn't sound excessive but in reality it is. A change to straight SAE40 oil is likely to reduce the amount, which I might change to. I will, as said before, fit a new Andover Norton (RGM)oil pump and monitor the drainage before refitting the cover (I don't think the big ends throughput reduces this amount as also explained above)...Will post again when done, but stupidly bought another old wreck of a bike yesterday and now have 3x rebuilds to get through...
Just drained the sump on m…
Just drained the sump on my '55 ES2 after an enforced absence (incident involving a cracked collar bone and two cracked ribs! Not on the Norton). The bike has not been used for some 5 or 6 weeks and I drained just under 1 pint - probably around 550ml. From my earlier post it would appear to level off after a period of time - almost, you might say, asymptotic. Presumably the resistance of draining down starts equalling the head available as the oil level lowers in the tank. Then there's the increasing viscosity as it cools down..........George
I got fed up with the mess…
I got fed up with the mess and fitted my 99 with a 3/8th pipe up to the tank and enlarged the tank breather pipe to the rear chain , easy to do using small bore gas copper fittings and plumbers solder,also easy to hide on a DL . I now have to oil the rear chain as little oil gets to it.Before this oil from the breather was lubing the rear tyre.I use 40 oil .If left for a month or so I drain the sump.I do get condensation in the tank so am working on raising the tank temperature in winter with a little tank insulation. I will fit a tap in the feed line.
Thanks for the update Robe…
Thanks for the update Robert. Yes taking the breather into the tank seems a good way of capturing the oil blow off. In fact this system is used on many later bikes, I know the later AMC (AJS- Matchless) machines do this. When one sits and analyses this method to look for negatives and potential problems the only ones I can come up with are:
1) If the machine has been left standing a long time considerable oil might have accumulated in the sump, so one must remember not to rev the engine for several minutes just in case the crankshaft and descending pistons creates too much pressure in the crankcase and blows the seal. The breather will obviously release pressure but as it is so small it won't be able to vent that quickly especially as with this new set up, the breather tube will now be full of oil that has to be pushed all the way to the oil tank nearly 2 feet higher before it can vent gas pressure out.
2) As regards piston blow by gases contaminating the oil...I don't think this will be an issue as the oil will always be in churning contact with them in the crankcase anyway.
3) Although the breather disc valve in theory prevents return flow the system might work better (not saying it will but worth trying) by fitting a simple valve on the actual outlet pipe from the tank. The one I always recommend is the Royal Enfield "Duck Bill" valve which is a simple flatted rubber tube (can be cut shorter) ...NB Some of the Indian Ebay versions are not too good as the rubber is too hard so they don't work...better off buying from "Hitchcocks"
3) The problem highlighted in (1) above might be reduced by fitting a breather to the rockers...as this will be clear from the sump oil no matter what the amount has collected. .Normally I would not recommend this but if you use a valved outlet on it, it should be OK, The only problem seen doing this is that the two breathers will have to remain separate all the way to the oil tank for fear of the sump oil filling the head. Perhaps the head breather could be valved and exhausted to free air as there shouldn't be too much oil blown out here.
________________________________
As regards the cold running oil I would recommend keeping the oil level in the tank at the very minimum level as halving the amount must result in the oil warming up twice as fast noting that the amount lubricating the engine remains the same but it is working better due to the higher temperature driving off moisture and flowing better....One precaution is that if wet sumping is very severe, then one has to check the level before starting just in case it's too low (always a good idea)....you might even find that the lower level results in a slower oil drainage rate .....
Les
Pretty obviously, gear pum…
Pretty obviously, gear pumps aren't going to be oil-tight but with everyday use the oil shouldn't get much chance to drain through in any significant quantity - assuming the pump isn't badly worn. Some wet-sumping is inevitable so if you don't use the bike every day, fit a sump plug with a drain screw, borrow a Pyrex measuring jug from the kitchen
and, before each start-up, measure the amount oil drained off. Dispose of that and fill to the same measure with fresh oil before starting. If you keep a log of mileage and amounts of oil replaced you could ascertain whether any regular oil changes are actually needed! You might well be replacing an oil tankful every 5,000 miles or less.
If you ARE sumping a significant amount of oil then you must check the tank level before starting up. Pump maintenance is pretty limited - grind the outer plate flat so that all the groove marks are removed and check the gear clearance to the body face by using a straight edge and feeler gauges. I don't know what the clearance should be but I would prefer something less than 5 thou - probably 2 to 3 thou. I will check my Jag workshop manual later as I used to overhaul their pumps - oil is oil!
Cheers, Lionel
I'm surprised that this t…
I'm surprised that this thread has gone on for so long, but thought I'd just add something to the brew.
3 bikes. 99, 77, and Commando. All hopelessly different oil-wise.
I had to fit a tap to the 99 itleakedpast the pump so badly. I could leave it for two weeks and it would smoke as if it was on naval manoeuvres. The 77 leaks abouthalf a tank in 6 weeks; I tend to drain the sump before starting, and the Commando doesn't leak much at all, though I do use it quite often. Went out on Tuesday for 50 miles. Stupidly cold, frozen stiff.
4years ago I fitted a new pump to the Commandowhen I found out that the oil was only getting back to the tankbecause of the pressure in the crank case.
Warning! Don't fit a tap. You will forget it, and its not because of your age!
I also have a Jubilee, but don't want to talk about oil in relation to that. Its a total loss system!!!!
Thereason formy diatribe is this. The oil pump is the heart of your Norton. If it leaks to a great extent, it is probably worn and the pressurewhen running could well be low. If Ifound that I hadlow blood pressure I would worry and probably at least have to change my underwear. In the interest of your Norton'sengine, if the pump worries you,don't dicker about with taps and valves, change the pump. It isn't a difficult job and it will give you piece of mind.It really is money well spent.
Only 33 years and we will be able to wish each other happy 20/50. Meanwhile, have a happy 2017.
Here is a question to cons…
Here is a question to consider:
On two bikes with equal milage and wear, one being a twin and the other being a single, which bike would be more prone to wet-sump?
I am thinking that there will be more drainage thru the roller bearing main on a single than past the plain bearings on a twin.
Yea or nay?
How long is a piece of string?!! In the 50?s I owned a Dominator 88, it never wet sumped enough to pump oil outof the breather. However my riding habits were different then. The bike was ridden nearly every day, and never stood idle for more than a few weeks. Also, because the bike was ridden hard, I used Castrol Grand Prix 50 grade oil, which, was less likely to seep through the oil pump. I now ride a very similar 54 Dominator, using 20/50 oil. This will pump out oil, if left more than a week. If my riding habits were the same, this would probably not occur. When I go on the week long Colombres Rally, there is no oil blown out when starting. My solution is to place a clean container under the breather pipe, and pour the oil back into the tank when it stops dripping.
