Hi on my Dominator 99 i seem to be missing a part from behind the stator to hold it in place? can any one confirm what is missing and what it is called.
i have attached a photo of what i believe it to be? but also i've seen pictures if some mounted on studs?
Any help in identifying would be great, i have looked in the manuals but i can't see any diagrams with engines showing a stator and rotor system.
ian
norton-domi-stator-mounting-plate-docx
It would be nice if you us…
The stator mounting as sho…
The stator mounting as shown in your illustration should be screwed directly to the drive side crankcase by 3 countersunk allen bolts. The stator itself is then held to the mounting by 3 studs and nuts.
Previously Gordon Johnston…
Thank you for your advise any idea where I can get the mount from?
Ian, most of the main supp…
Ian, most of the main suppliers will have stator mounts, RGM for example where I bought my last one. There is one on US fleebay for sale too but if you have no luck I should be able to find one for you.
Fritz has a point, but if using Word when sending to a large community I always find it best to send out on Word 97-2003, even people on the newer version can open that.
Good Luck.
Previously ian_legg wrote:…
â?any idea where I can get the mount from?
I've believe there are different stator fixing studs. It depends on the year. Part# 20691 for 1961, 21433 for 1962. The later is, I believe, from 1962 on for all Domies and Atlas.
Have a look here https://nortonmotors.de/en (search for ?stator stud?) you should ask Joe Seiffert which is the correct one for your bike.
Fritz
It would be nice if you use PDF, not everybody is used to Windows and Word.
Fritz
