Can't seem to find a decent description of what should be. I have a fair assortment of fittings that have come from our suppliers ,none of which seem to want to work together as they should. My understanding is that the rubbers should compress enough to grip the tank and not allow rattles but the bolts should tighten to a positive stop so that they do not vibrate loose as the tank moves on the rubber. No one seems to market these as a set (which one hopes has been tested to work) so we finish up with a random selection of bits with no measurements.
About 3 years ago I bought…
Interesting David, my sets…
Interesting David, my sets comprise of 12 items ,6 each side, A part threaded bolt a washer a steel cup a top hat rubber a plain rubber washer and a large steel washer . Nothing like yours!, can't find a picture or description . RGM at least give a detailed description of a top hat rubber ,but thats it.Andover has nothing, Norville has no worthwhile decription or pictures .No one has a set.
That sounds OK. I can't r…
That sounds OK. I can't remember if I have one flat and one cup but no matter. I'd better go and have a look rather than rely on possibly faulty memory. I'll try and take a photo later.
Perhaps the earlier bikes…
Perhaps the earlier bikes have a picture or description, Be nice to have a few more opinions .I have a Norton parts list!, the front fixings amount to 10 total items, Bolt, washer for bolt, steel cup ,rubber washer , rubber washer. The rubber washers have no description and there are 2 types so at least one is a top hat. no steel washers above the frame.
The 16H picture looks corr…
The 16H picture looks correct, as long as the top rubber washer of a top hat design goes through the tank mount to make contact with the bottom rubber washer that sits in the cup.
I bought 2 of each for my 99 the year before last from RGM. The cup and shouldered bolt with very long hexagon (AF) in Stainless.
Hi David, According to the…
Hi David, According to the Norton parts list you are missing the washer between bolt and cup, this would affect the degree the rubber tightens a little. I suspect if both rubbers are top hat design then the upper one will be larger diameter or thicker than the lower one as its a different part number.I have tried your set up and it appears better than mine but the thread does not lock up.
The order on mine for top…
The order on mine for top to bottom is:threaded plate welded to tankcircular steel washer (to provide a circular bearing surface for the next item)circular rubber (I'd have to take it off to see if it has top hat arrangement)lug welded to framecircular rubber (again I don't remember if this also has a top hat or the other one does - or both)large round cup washerbolt headThe bolt is shouldered and long enough for the shoulder to be tight on the tank threaded plate, whilst short enough to give the two rubbers a good squeeze.I don't think this had another washer between the cup and bolt head but if that is what the parts list says then the PO missed it out before the early 1960's when it was last on the road before I took it on. Unless the washer at the top belongs at the bottom. But then the tank lug would not provide a full size circular surface for the top rubber.I've no idea why there is only one cup washer.The top hat goes through the frame lug (not the tank plate - that would not work) to meet the other rubber below (I don't see any reason for which type of rubber goes on top as long as at least one top hat fills the hole in the frame lug). So the top hat insulates all the steelwork from the frame lug with the bolt fully tight.The Dommie is the same but it's less accessible and harder to photograph. I had no idea that any sizes differed. I'm pretty sure it's all interchangeable but Norton seem to have take fiendish delight in making unnecessary changes!I can measure it tonight if you want to work out why the thread won't lock up solid.(ps - my speedo cable is looking a bit rougher than I expected! Needs to be tied better by the looks of things... the sidecar lug seems to be attacking it...)
I used the shouldered bolt…
I used the shouldered bolts but I bought a lot of big rubber washers and experimented til the tank floated above the frame on a rubber cushion. I have rubber washers above and below the frame brackets.
Previously robert_tuck wro…
Previously robert_tuck wrote:
Interesting David, my sets comprise of 12 items ,6 each side, A part threaded bolt a washer a steel cup a top hat rubber a plain rubber washer and a large steel washer . Nothing like yours!, can't find a picture or description . RGM at least give a detailed description of a top hat rubber ,but thats it.Andover has nothing, Norvil has no worthwhile decription or pictures .No one has a set.
Hi David,I also have had t…
Hi David,I also have had the large steel washers against the tank for years but according to the Bracebridge St parts list they should not be there,and it seems to work without them. Try again Anna, I'm all ears.
Read the parts list. Look…
Read the parts list. Look at the exploded drawings.Then contact Norvil or simply read their on line parts list. All of the parts are listed and priced. It is a very simple arrangement and the discussions on here are making the whole arrangement sound complex when it is not.
Tha only picture I have fo…
Tha only picture I have found us in the WD Norton manual. Page 1o has a good picture and is identical to mine. No flat washer at the bottom.
My Dommie spares list is totally confusing. Two bolts at different sizes and 2 cup washers.
Previously michael_jobson…
If it was that easy we would not be asking, which exploded drg?,where?, If it was well detailed then the suppliers would know what to supply instead of the random collection of completely useless parts they sent me last time.
Robert: According to the p…
Robert: According to the parts list I have for my 1961 Model 50 the petrol tank fittings are shown to be:
2ea 16237 Frame mounting rubber for petrol tanl
2ea 22081 Frame fixing bolts
2ea 22082 Rubber washers for fixing bolts, top
2ea E6743 Rubber washers for fixing bolts, bottom
2ea E6742 Steel cups for rubber washers
2ea 10914 Washers (steel) for steel cups
If I remember correctly. the bottom rubber washer has a step in it that fits inside the hole in the frame tab. Or is it the other way around?
5 items per mounting is wh…
5 items per mounting is what I understand ,but as they are not pictured or dimensionly described even the suppliers staff picking these for orders get it wrong ,with the result that the bolts don't lock up and work loose to fall out or worse they don't even have holes in for the bolts. The stepped washer goes in the bottom and sits in the cup. I stick the plain thick top washer to the frame with UHU or similar contact adhesive, Compared to some other makes Norton parts are very poorly drawn or described although RGM is making an effort.I also think they could be sold as a "set" which would also make the suppliers more responsible for them to be "Fit for purpose ".
I could not find them eith…
I could not find them either. I just used tbick rubbers which once acted as bump stops for the rear shocks on a merc..others will also fit! The tank dies nit move. No vibes and it looks original at a casual glance.
I've found a picture on N…
I've found a picture on Norvil's web site: http://www.norvilmotorcycle.co.uk/techtalk32.htm
Fritz
PS: Couldn't remove the attachment
petrol-tank-fixing-norvil-motorcycles-tech-talk
Well done Fritz, I never f…
Well done Fritz, I never found those details. Still not definative though as the diagram depicts the flat washer as being very thin (its not) and the photo (which should be more accurate) shows the stepped washer about twice as thick as it should be!, This thick/thin business is important as if its not correct those bikes that actually get ridden will lose the bolts sooner or later if the assembly does not fully lock up. Alright for trailer queens though.
I know this isn't about H…
I know this isn't about Heavy Twins as the original article but the thread seems to have strayed away to include 16H. The attached photo shows the arrangement of the tank fixings for my 1955 ES2, which was used for many years.
This is very similar to my 1969 Mercury, although the bolt head changed from Whitworth to AF spanner sizes. The top hat washer sits on top of the frame brackets and the plain rubber washer below; this ensures that the bolt and tank are totally isolated from the frame. I've never seen or used the metal packing washer (A2/275) mentioned in the parts list, but all has worked well since buying the ES2 in 1970!
I recently purchased the stepped bolt (A2/277) and the steel washer cups (A2/279) from the NOC spares scheme. I think I bought the rubber washers from Jeff Hunter Engineering from the VMCC autojumble at the Bath and West Showground.
Philip Ham.
tank-mountings-3-jpg
Thanks Phil and others who…
Thanks Phil and others who have replied, I think I will try that,although I dont want AF hexagons on my bike so will try to stick with the old rusty bolts. I will probably have to cut down the top hat rubbers to get to a lock up situation and it would make sense to include a thin large steel washer against the tank though it would have to be stuck to the rubber for ease of fitting. Shame no one supplies a "set" of parts that can be trusted to work.Perhaps they know the parts are a missmatch!!.
Robert,
The stepped bolt in my photo is NOS from NOC spares and is 5/16" WW.
Phil.
I've changed the setup. I…
I've changed the setup. I' use a screw which goes to the thread in the Tank. Less fiddeling arround with the rubbers and steel cups. No more risk to damage the coating on the tank while trying to hit the holes.
Fritz
Edit:
My writing above is completley rubish.
I've changed to bolts ?loctited" in the tank, instead of screws.
I don't read the NOC mess…
I don't read the NOC messages an a daily basis and have just returned to this thread to see how it ended. The initial query asked about how the front mounting was made up on a Slimline tank. After some discussion the schematic, and it only that and is not to scale, and its accompanying photo were found on the Norvil website. these clearly show exactly how the Norton mounts were designed and fitted, and from my own experience it works exceptionally well.
Then having had that information the original poster became critical of suppliers who did not supply a "kit of parts" for this arrangement. Which makes me wonder just how hard some people actually look. I know that in the modern age people generally expect to have instant solutions presented to them and so they just do not research things in depth. The advent of social media in all its forms encourages this I am afraid. So did RT actually look closely into the availability of a "kit of parts" for his Slimline tank? I know not, but Ido know that if he and others had looked at the Norvil site they would see a heading at the top of the home page which lists "Kits". Item 28 in that list is headed "Petrol Tank, and in this list arecomplete kits of parts for the fixing of tanks forHeavyweight Twins, Singles and Commandos. It lists a kit 067384: Kit: Petrol Tank: Slimline Featherbed: Including bolts.
Like I said earlier if the tank is fitted as shown in the schematic and the photo it will be secure. If you are concerned about losing a fixing bolt in use then simply Loctite them or fit locking wire. The correct bolt is stepped and when tightened it compresses the rubber the required amount to allow the rubbers to operate as anti vibration mounts. The tank itself was built with a reinforced insert into which the bolts fit so there is absolutely no need to fit a washer between the bolt shoulder and the bottom of the tank. HTH
About 3 years ago I bought a set of four for my prewar 16H and they are identical to the pair at the front of the Dommie tank. One design detail Norton never changed for well over 35 years!
As you say - shouldered bolts so they are fully tightened hard up. Top hat rubber washers above and below the tank plate and meeting each other in the hole in the tank plate. Steel disc washer with turned-up edges above and below the top hat rubbers to transfer the squeeze from the bolts.
Aren't they listed by Andover Norton? I suspect that's where mine came from.
David
