I bought an engine on Evil-Bay and on stripping it down with a friend's help, it was found to have mismatched Con Rods in it, one from a 650 and one from an Atlas, so I will show my further ignorance and ask for Norton Heavy Twins are Connecting Rods Left and right handed and marked as such?
Many Thanks
Possibly clueless-John
The 650 and the Atlas used…
Hiyah john - Not quite cor…
Hiyah john - Not quite correct John. Early 650s and early Atlases used the same con-rods ( not handed ) . Some years later they both changed to a stronger rod. Then subsequently a hole was added to one side of the rod to spray a mist on the dry-side of the barrel. These changes happened to 650s and Atlases around the same time. So you may have a mix of types but not Models. Cheers for now, Howard
I could add a picture of t…
I could add a picture of the differences but I do not know how to.
Previously anthony_curzon…
Go to attachments Tab and browse your Computer then click, (on mine, Linux based), you click OPEN, on yours it may be ADD picture or something similar!
Found shots on Ebay, these are exactly like, what was in the Atlas engine, I bought these only to find the Stronger rod marked on the end elevation side, (long finger side), not shown in the Selle'rs pictures, there is a bit of a scam going on, on EBay where by the post some pictures to play a part in the description and then do not provide adequate word descriptions to match, so he, the Seller didn't post a shot of the side-ways elevation Con-rod damage, he also puts a Disclaimer where He will delete your negative Feedback if you don't talk to him first!
John
Webmaster edit: Attachment removed at request of poster.Attachments
Previously howard_robinson…
Thanks, why design a fragile engine?
This is when I get frustrated by Motorcycle products, their Designers, Engineers and interfering Bean counters, if I had been talented in that direction I would have built the best engine I could of... and benefited by reputation on engine strength and durability!
John
Anthony, Perhaps the engin…
Anthony,
Perhaps the engines I have got can be modified to encompass changes too!
John
Howard,
My Grandad was a Robinson! Based in Lancashire and with his brothers, Mining and railway workers, Wigan, Coppull, Mossy-Lea region, Wrightington! Then some of them went to Yorkshire, enemy country, to Carlton Main pit, near Barnsley
Thanks for correcting my lack of in-depth familiarity with heavy twins!
John
Anthony, My friend has an…
Anthony,
My friend has an Hillman Imp engine in a RE Constellation frame and it has done 300,000 miles without a major strip down!
John
Designers do no build frag…
Designers do no build fragile machines if they can help it. Metal fatigue is the big issue with con rods. And the variation in life for identical parts can be huge. It takes large samples to get the data and that's a problem, especially for a small company in difficult financial times.
If today's computer analysis had been possible, they could have improved the life by reducing locally higher stress.
Imps should be good...with shorter stroke the con rod forces are much lower.
Norton could have added more weight but vibration would be worsened.
John hello again - for man…
John hello again - for many years the early 650SS con-rods performed very well and especially so in the Thruxton 500 Mile races in the early sixties. I believe it was only when tuner entrants like Paul Dunstall and the like started serious tuning on the 650SS and Atlases that a stronger rod was required. Seemingly when revving at 7K and having a piston seize caused the rod to snap at the base. Curious ? I have used and raced the early rods satisfactorily for many miles, though I have to confess that 7K in top was only a dream. A word of caution though - please be sure to use a pair of whichever type you have. One of each is a no no ! Regards, Howard from Lancashire !
Hello, That Friend of Mr J…
Hello, That Friend of Mr John Hall Is ME!!! one Anna J Dixon.Bs.mech and both connecting rods have NO oil holes the early type and the later Canoe V shaped type has well the guy who had built this motor had used blue silicon sealant in doing so he laddered it on blocking up the scavengeside hole in the crankcase we seem to get these numpties now and again the crank now needs a regrind has a result of his improper action and thoughtlessness, But OLD annaj will put things right in time, yours Anna J
Previously john_hall1 wrot…
John
I wonder what the real iss…
I wonder what the real issue is with mismatched con rods? Any weight difference will produce a rocking couple - but that will surely be much smaller than the out of balance inherent in a parallel twin.
And at the best part of £190 each, there has to be a very good reason to throw a con rod away!
Just asking...
Previously David Cooper wr…
Just asking...
It looks like the engine has been seized at some point and perhaps someone has just cobbled the bits together together to make it saleable/swop-able it certainly, I would have thought be a bad idea to run with mismatched Con rods from a balance factor alone!
John
Previously anna jeannette…
Yep, left the motor in a right mess and a much more costly rebuild!
John
Hello well one thing is you have now two set of conrod that need balancing up and one crankshaft that needs a regrind and a new set of main bearings FROM R&M the canshaft is in very good order no signs of wear as is the followers the barrel is a other story , best left S.E.P engineering. for a recreation job this bit will cost the most howch !! But at the end of this proess you have a 3 million dollers Atlas engine yours Anna J
John
Hi John, You have our symp…
Hi John,
You have our sympathy regarding eBay purchases... Most of us have been there. Anyway, I would suggest for peace of mind going for a set of new rods and putting your existing rods on ebay. You should at least recoup some of your expense. Thereafter, Norton engines are not difficult to rebuild with a bit of common sense and a good read of the manual.
As for bike design, if you look at a Norton Twin from one end to another it is full of engineering "compromises" but the whole is better than the sum of its parts which may explain why so many of us persevere with them long after their scrap-by date. The other explanation is sheer lunacy.
Not entirely lunacy, Gordo…
Not entirely lunacy, Gordon. My first Norton was a '53 88, bought, second hand, when I was 19 years old. Not the fastest bike on the road, but the best roadholding. Over any reasonably long distance, it could keep up with, or beat, almost any other bike available. I now ride a '54 model. However, not quite so hard! Although I find the "Runs", at the rallies I have attended, to be boringly slow. I very rarely ride on motorways, but, on normal roads (better in Spain than in the U.K.!), seldom get overtaken.
John, totally agree about…
John, totally agree about the dismal pace of organised runs. You see a group of cyclists in the distance and 10 mins later you can still see a group of cyclists in the distance... I invariably arrive at various stops 20 mins before the rest.
The early 50s bikes were in my eyes far better engineered than the later ones. I have a 1951 A7 Star Twin which I have had for 40 years now. It gets used hard and often and has never failed to get me home (are you listening dear Norton?). I wouldn't hesitate to take it any distance.
We seem to have a lot in c…
We seem to have a lot in common Gordon, but, must not hog this thread.
John
I prefer a six million Dollar machine, I presume you are referring to a pun on the Lee Majors character of the 70s & 80s!
John
You know Howard, this is how the Jap bikes scored especially Honda in the early days, with free-revving engines and motors that were nigh on unburstable, I have a Kawasaki ZL400 that red-lines at 12,000 rpm, ultra-short-stroke 44mm i think almost like a Honda 50.
I did read that in the old days, BMW engines had a 25-30% safety factor, you got 60bhp and the engine was safe up to high 70s!
John
Racing indeed does improve the breed!
You know Howard that is where, Japanese bikes scored in the early days, high RPM and almost unburstable engines, especially Honda! I have a mid-sizes Kawasaki ZL that revs to 12.000 rpm, ultra-short stroke 44mmm I think, almost the same as a Honda 50! I read some years ago that the Old BMW engines especially the K Series had in design 25% to 30% safety margins you got 75bhp and the engine could run to 100bhp!
John
Just asking...
Suspect the engine was put together from a collection of spare parts, even I can spot the fake bikes on Ebay that claim to be RGS and 650SS etc, I know Club Members would not do this but because of the "Investment" Value of machines, all kinds of Scammers and Riff-raff are on into the Classic Vintage Bike scene now!
John
Previously Gordon Johnston…
Previously Gordon Johnston wrote:
Hi John,
Isn't it a facet of Synergy the " Sum of the parts" performing better than an analysis of components, I have read that in Eastern religions of the Far East a Motorcycle and it's component parts are not exactly thought of as inanimate as we probably mistakenly would think of them in the West. I have had motorcycles that seemed to have their own character funnily enough the British ones always had most of this elusive quality without the philosophy 0f Zen behind them! It's a Deva thing...I am assured!
John
Hi John,
John
Hello We did have four cylinderengine design for motorcycle some like the BRM of 1949 was years ahead of this time we had the Engineers But Not the Management the light was On but no one at home !!!
Anna, They, Norton, BSA co…
Anna,
They, Norton, BSA could have easily modified a Coventry Climax Featherweight engine like Rootes did with the Hillman Imp engine, from the Mark 2 version, stronger block variety, giving 55/60 bhp straight off the mark!
This could have been at least 5 years before Honda and Kawasaki did it> The original Rondine later modified by Gilera was designed in the early to mid 1930s! The Italians get very little credit for engineering the first really successful across the frame four!
The nice link to Norton with the Rootes Imp engine is Leo Kuzmicki was involved in the design and development of the Imp engine, where earlier on in his career, he being a Cylinder Head specialist, had tuned the 20M and 30M Manx racing engines!
Geoff Duke asked for a 4 in 1951/52 and he then left for Gilera, when Norton/ the British Industry failed to supply the 4 cylinder engine needed, the writing was on the wall, pre WW2, He left Norton, with much personal criticism from detractors who accused him of being disloyal! Jock West and BMW anyone?
John
The 650 and the Atlas used the same con-rods, but there was an earlier one and a later one as there was also a modified one with an oil hole. The earlier 650 and Atlas con-rods were on the fragile side. The way to tell is the earlier con-rods had a large circular cut out at the base of the con-rod and the later ones had a V shape and then that oil hole was added to pass oil onto the cylinder wall bores. There was many oiling modifications performed on the crankcases, oil junction block and piston rings.
