Hi everyone,
I'm a happy new owner to a 1953 (edited) Dominator 88. After my recent purchase of a 1972 Commando 750 in March, and spent the short few months making it run properly (as well as looking pretty) with help from members on this forum. Since the commando, I wanted something from the Dominator era, and this very bike caught my eye.
Just received delivery of the bike here in Dresden, bought from a firm in the Uk called Spinning Wheels.
Now having started the bike for a very short test ride, I'm sure I'll have some questions about the bike for the ever informing members in this club.
Happy days.
Rich.
Hi John, Correction after…
Hi John,
Correction after checking all the info I got.
I had asked Mr. Seifert at Norton GmbH, the records search here, as well as VMCC, all confirming production was 09.10.1953.
But was sold and first registered somewhere after 01.04.1955.
Rich
Previously richard_chan wr…
hello your Nortonis date stamp marked on the top lug of the frame to see this you need to remove seat and tank this lug holes the head steady it's in very small numbers and a may be a letter to my 1954 Dominator is stamped D/4/54 built April1954 I have been telling Nortonowners for some time but no one seems to be bothered and still go down the factory records route which only lets you the despatch date and theinformation on this yours Anna jHi John,
Rich
Hi again Rich, You are a l…
Hi again Rich, You are a lucky man! You have one of the best Dominators ever built, before AMC started cutting corners, to save a few pence, and trying to boost performance (to match their arch rivals Triumph.
The 500 cc motor was now highly stress, and, with the iron head, ran smoothly, with less vibration than later models. The top speed (not that I suggest using it, on such a classic bike) should be a touch over 90 m.p.h. quite fast enough, off motorways, and the handling superb.
You may be interested to know, you can get a photo copied manual from the British National Motorcycle Museum. Although a few small items, from the original, are missing, it is one of the very few manuals available for this model.
Being built in October ?53, it is probably a ?54 model, with the slightly better 8" front brake.
I know it is along way from Dresden to Belgium, but, if you can make the International Rally I would love to see your bike, and compare it to my ?54 88.
Regards, John.
Hello Anna and John,Re: pr…
Hello Anna and John,Re: production date - ibwas not aware of this method you mentioned Anna. I figured Mr. Seifert would be pretty knowledgeable as he has helped me a lot with great advice throughout my Commando work, as well as owning the records. But I'll check it out next time I get the tank off. Re: John - good to hear a message of positive confidence in my new (to me) bike. I wish it was all original. But it was Fitted with period BSA Rocket Gold Star front brake being 190 mm and a 1956 AMC gear box which Norton fitted in 1956. Other than that, the bike was fully restored with detail pictures and documents. I would love to be at the rally, but with two little boys both under 3 years old, it'll be hard to get a free pass to go riding for a week and leave the family behind.In regards to the bike , the questions begins. I took it out in the city for a ride today, it had all gone very well for the 20mins ride to my destination. On the way back, probably 2 mins away from home, the bike idles a bit weird and dies at the lights. Couldn't get it to start for about 20 minutes, then all of the sudden it kicked over again. I figured it's a carb issue at this stage. So I first check the spark plugs when I got home. They were both black. Which to me means too rich. So needle DOWN one clip perhaps? And maybe pilot jet is blocked a bit? Would I need to take the entire carb off for cleaning? Thanks.Rich.hello well since I have owned Nortons for 40 years or more and own a 1954 model 88 and rebuilt it from ground up I know these things the bike tells its own tail if you know where to look just scrape some paint off the top lug next the head stock and you see very small stamp marks thatthe date of manufacture so look for your self-do not really on data as I have done years of research and foundthe information give on the record is out and in some cases as much as ten months out, yours anna j
Bad behavour when warm is…
Bad behavour when warm is often the magneto acting up which would also dirty up the plugs. Sometimes its just a too rich mixture which is helpfull when cold but soon soots up the plugs when hot. Put in some new plugs and repeat the exercise and when the bike wont start take out the plugs and kick over with a new plug held against the head and look for a nice blue spark ,if its not there ,its ignition, most likely the mag condenser.
Rich, has your bike been r…
Rich, has your bike been rebuilt with an iron, or alloy head? If iron, check to see if you have steel, or alloy, pushrods. Steel rods were used with the iron head, alloys expand more when hot, and you lose valve clearance. You CAN use alloy pushrods, but, valve clearance should be increased to 6 thou inlet, and 8 exhaust. I had the same symptom you describe. Spent hours adjusting ignition timing, and carb, before Phil Hannam put me right.
Hi Robert and John, Thanks…
Hi Robert and John,
Thanks for your replies.
I assumed also it was running rich, so I dropped the needle down on clip. The bike wasn't happy with this at all. Sluggish on pull away and coughed with throttle and pilot screw adjusted.
So went back to middle clip, cleaned out the carbs as much as I can. I ran good again. Tho it is hard to tell if it is the ignition fault at the moment, as I have no new spark plugs available.
Speaking of spark plugs - what is recommended?
Re: John - I have also checked while cleaning the carb. I have a T2225 on the head, which means an alloy head. So assuming this, should I be using a Champion N5C / NGK B6ES with 0.020" gap as recommended? Right now, N5C are on there. And they seems hard to come by.
As for the push rods, I wouldn't have a clue what was put on, I'm again assuming now knowing it's a alloy head, that the previous owner had put in alloy rods too?
In other questions - the clutch is very heavy on the bike. The bite limit is also very small. I also have to open my hand fully to feel the clutch bite, is they normal? I also find it hard to find neutral as well, having to keep looking down to double check. I took the Commando out after a short ride on the Dominator, and my word... The Commando is soooooo smooth compared to the Dominator. Tho riding position on the Dominator is brilliant, much more aggressive than my other bikes. Almost feel like a chopper.
Thanks again.
Rich.
Sorry to be a "Doomer" Ric…
Sorry to be a "Doomer" Rich. Being built in October ?53, your bike could be an early ?54 model. It would not originally had an alloy cylinder head. What is the engine number? The ?54 model would be stamped J122, with the serial number above. Being over 60 years old, many non standard, or later parts may have been used when it was rebuilt. I use NGK B6HS plugs, and, despite some enthusiastic use, these have not been changed for over 12 years.
You are bound to have "teething problems" with a bike of this age, but if you persevere, it will be worth it. A good Dominator should run smoother, and require less maintenance than a Commando. However it will never have such a brutal surge of power.
Correct. J122 serial. Mr.…
Correct. J122 serial. Mr. Seifert also said it's a 1954.
As for the plugs - I know the B6HS can be used on iron heads, and alloy heads are B6ES, so there lies the confusion. Should I be using one or the other? Or no difference?
I know the bike have had complete work done on it, I guess now I need to go through and check all the documents and receipts for what was done.
Rich
Hello I now use BOSCH W8DTC these are better for ethanol petrol and their self-cleaning OR you can get Champion N9BYC which have the same Heat Rating Has N5C and So does BoschW8DTC these plugs were made for ethanol fuels and do not have any type of resistors so there OK for a magneto use, has magnetos do not like Resistors they give the Magento a hard time and eventually damages the condenser in side the magneto so go have fun yours anna jHi Robert and John,
Thanks again.
Rich.
Hi Anna, Thanks for the ti…
Hi Anna,
Thanks for the tip.
I'll see if I can locate the items you mentioned. Champion is hard to come by here for some reason, NGK and Bosch is easy of course.
Hopefully I'll have the bike properly registered tomorrow without issues and be home without the authentic old bike experience again.
B6HS is a 1/2" reach suita…
B6HS is a 1/2" reach suitable for iron heads, B6ES is 3/4" reach, suitable for aluminium heads only. NGK are excellent in my experience and last for years.
Hi again everyone, Bike re…
Hi again everyone,Bike registered and on road, now for the tuning it needs.I have checked on the bike - it has a AMAL 376/77 carb on it. Which from what I gather, is for a T100.I've emailed AMAL, they suggest that a 376/19 is for the Dominator, but on their website, it is listed for 1955-1956.Does anyone (John and Anna maybe) know the correct carb for the 1954?I'm wondering why they went to a different number carb tbh...
Thanks again
Rich
Hello again, Ive order a v…
Hello again,
Ive order a various types of spark plugs. The original Champion N5C as well as champion N9BYC.
I have found that the previous owner has installed a Pazon surefire 6V unit with magneto on the bike.
FOR THE N9BYC, would I need to also use non resistance caps with it? Or the regular NGK cap will do? Would a regular resistor cap be problematic for the non resistor spark plugs?
Would a non resistor cap/plug be problematic for the surefire unit?
Their site is not clear on this.
Rich.
Thanks again
Rich
For 1951 to 1954, they used a (2)?76 amal , 1" choke with 170 main jet, 3 1/2 cutaway slide, Needle position 2, Needle jet, .107
From 1955 to 1963, they used the ,then new, 376 monoblock with 1"choke, 240 Main jet, 30 pilot jet,3 1/2 Slide, Needle position 2, Needle jet .106
Hope this helps.
Don't forget that these jet sizes etc. were set for fuels which differ quie s lot from those available today.
Thanks Charles for the rep…
Thanks Charles for the reply and information.
The 376/19 (second one you stated) is basically what I have right now. Except I have found some scoring on the barrel , so went with a new one from Amal.
Any previous versions can no longer be purchased anymore as far as I can see.
I'll keep it on the standard setting and try it out , adjust accordingly.
Thanks again
Rich
Hi, yet again Rich. The or…
Hi, yet again Rich. The original 276 Amal is still available, but, at a price! (almost 100 pounds more than the 376 monobloc, plus tax). Since you already have a later cylinder head, it would be pointless fitting the older type carb.
Thanks John, That makes to…
Thanks John,
That makes total sense. I just assumed the previous owner had his reasons.
Anyways, carb is here tomorrow. The bike is idling less than perfect at the moment, should be much better once it has a new carb.
Rich.
Hi, I can't find these…
I can't find these small dating numbers on mine. perhaps I'm looking in the wrong place ? I don't want to go scraping paint of randomly ... any chance of a pic / sketch showing location please ? :) Mne is a black frame Domi 88 reg Jan 1954. It's not been on the road since 1963 ... so plenty to do. All original as my late dad was the original owner. Engine is J122. 55XXX
Thanks in advance
Frame Photos
Check out the attachments.
The Frame year of manufacture should be on the top edge of the Head Steady Bracket.
The Frame number should be on the left hand side bracket the Swinging Arm is attached to.
Both can be hard to find under fresh thick paint.
Frame date
Anna; doesn't the lug stamp refer to the frame build date rather than the finished article? Who applied the stamp Norton or Reynolds??
Just curious...
Stay safe
Frame date.
Jon, I think you will find that the date was applied by the frame manufacturer and is when the frame was made . Stan Dibben assured me this was correct when I spoke to him concerning my 51 Featherbed.
Hi Rich, One point, is it a ?54 model (with iron head, and bolt on rear sub frame) or, the ?55, with several minor differences?
