On page 111 of P.L. Garrett's manual, when fitting timing sprocket and chains for Models 88, 99 and 650 from 1958, he says to fit a THICK washer to the camshaft and then fit the woodruff key.
I cannot find this washer listed in any of the post 1958 parts books.
The earlier parts books do list a thin washer for the camshaft on the dynamo models to space the fibredrive dynamo gear.
Does anyone know whether there is a washer on the camshaft of the alternator Dominators?
Hello Ian , There are no w…
Previously ian_richtsteig…
Hello there is No thick washer on the Norton Manxman 650 on the camshaft end where the camshaft sprocket fits but there is a thrust washer on the intermeadate gear shaft , yours anna j
Previously howard_robinson…
Previously howard_robinson wrote:
Hello Ian , There are no washers on the camshaft any of mine, nor have I ever seen such on alternator type engines. There is a hard washer that must be fitted before the half-timing pinion goes in place. Regards, Howard
Thanks Howard,
I thought that was the case as I haven't fitted a washer before on any of my alternator bikes but Garrett made me doubt my knowledge. Yes I always fit the hardened washer before the intermediate gear is fitted.
regards
Thanks Howard,
regards
Hello Unless this manual is referring to fitting the commando camshaft into a dominator crankcases wherethe Commando camshaft has no shoulder they fitted a trust washer, then this may explainthis good luck yours anna j
