dating for registration
I have an atlas with all the relevant US paper work but when i tried to register it the forms were sent back with the message that there was no date of manufacture on the title, can i get a certification of date without having to rub all the paint off the frame ? All the numbers are on the US titles that i have for this bike.It is not standard apart from frame, forks, wheels, engine & gearbox, it now sports alloy tanks & mudguards.
hello the build date stamps mark in very small numbers on the edge of the top lug of the head steady for the cylinder head the frame number on the left-hand gusset plate has is the engine numbers yours anna j
I took some photos before I had the frame painted, but can't find them.
this is the reply I got. See photo
img_1163-jpg
You need to send a letter or email to Dave Cattonfor adating letter , and you will also have to send him pictures of the engine and frame numbers as well as the complete bike. The DVLA will want a dating letter from the club that you belong to. In this case the NOC, so once you have that dating letter then they will consider and let you have a registration number. You will also need it to be MOTed, and have it insured. You also need to send proof of identity and proof of residence. and you will also have to fill in the application form V75/5 I think it is. I have done this with all of my bikes and I have got registration numbers. This was when they had local offices that you could go into and actually talk to some one. I have also done it via the post and if all the paper work is correct for the DVLA then you get a registration number allocated to you in under two weeks.
The documents that came with the bikes I imported from Norton America had dates on them but it so much easier to get a dating letter for the bike from the relevant clubs dating officer. The DVLA also look up the clubs that they accept a dating letter from as they did this to me when I sat there with all my documents to check if the dating letter that I submitted came from a DVLA approved club.
One last question, where can I find an email address for Dave Catton ? Looked all over the site.
Dave Cattontwinrecords@nortonownersclub.org
If you look at the front of Roadholder you will see very one who has a post on the committee listed there.
Hello with all respects to hard working Dave Catton he can only give you what he has in respectsto the factory record he holdes which will not tell you the date of build only the despatch date and engine and frame numbers the build date is stamped on the frame you have to look and find it , is painted over by now, yours anna j
