Hi Campbell Adie Aberdeen,I am trying to remove the on/of light switch from the headlamp switch panel on the above. I have removed the lighting switch knob which leaves the bakelite bezel plate. I am unable to get any movement on it or on the main body of the switch on the underside of the panel There appears to be no fixing screws or clips holding them in place, apart from forcing it off with the inevitable breaking of the bakelite anyone out there worked on this part, I have tried WD40 and gentle heat but to no avail. Thanks in anticipation on any replies. Campbell
Hi Campbell. Is it the typ…
Previously donald_campbell…
hello I have a spare U38 Lightingswitch brand new fits later Norton up to1957 dyno models, the wire clips are sold separately, see eBayroyal enfield lighting switch clip
yours anna j
Previously ian_soady wrote…
Previously ian_soady wrote:
Hi Campbell.
Is it the type in the image? These have a wire spring clip on the inside of the shell.
Hi Ian it appears to be the same but there is no holding clip behind I will get in touch with Anna, thanks for your help. Campbell
Previously anna jeannette…
yours anna j
Hi Anna, thanks very much…
Hi Anna, thanks very much for replying if you don't need your switch i will be pleased to buy it from you. the one on the headlamp shell does not have the retaining clip nor any obvious screw or nut holding it in place so trying to remove it will require persausion and the inevitable damage. Let me know how to go about getting in touch and paying Regards Campbell
Hi Campbell.
http://www.mopedland.co.uk/electro/elswitch08.jpg
