Rocker Spindle Shims
I am going to do away with the 'Thackery' washers on the inside of the rocker spindles and use shims instead on my 99.
I have never liked thackery washers as they cause unnecessary friction on the rocker arm and are quite a primitive way of doing things - although, they are foolproof to fit.
My question is to anyone that knows, how much side clearance to use? I was thinking of 0.002" - 0.003" and reasoned that the head will expand more than the rocker when hot and therefore the clearance will increase. If anyone knows different, please let me know.
I would also check that the shafts locate with the outer plates and are not free to revolve,may be necessary to pack the shafts or fit the RGM repair kit.
Hello the Thackery washers are there for a proposeand that to keep the rocker arm to one side and in its place, and do not have any friction on the rocker arm or spindles the Thackerywashers fit nearest the middle of the cylinder head space, So not a good idea to remove them all together So See RGM motor and ask Rodger's advise they do have sets of new ones, and you need to check you have oil going into the rocker spindles from the return side, hope you get thing sorted, yours anna j
Bob
I quite like the idea and think you are on about something here.
I have done this on in the past and have experienced no problems whatsoever.
In place of the thackery washer I made bronze washers. Be sure to use steel shims against aluminium !
Clearance may be down to zero as long as the rockers move freely.
Arne
Previously arne_eftestol wrote:
Bob
Arne
Hi Arne,
Thank you for confirming this, I have measured all the gaps that the thackery washers took up and the gaps vary from 0.119" to 0.130" so I have ordered a set of shims from RGM and will get the rocker centres adjusted to be nuts on with valve stem (although they are close already). Set of shims was only £10 including postage - so definitely not worth fitting new thackeries - especially considering their shortcomings.
Hi Bob,You say "I have never liked Thackery washers as they cause unnecessary friction on the rocker arm and are quite a primitive way of doing things", but sometimes the primitive way is quite ok.They are much easier to assemble than a stack of shims and as Anna says, by keeping the rocker always pushed in one direction, they can/will reduce valvetrain noise too. As for increased friction, whilst a "shimmed to minimal clearance" should be freer to move than one with the side play taken up by a light spring, I very much doubt that you can actually measure the difference in friction without access to some incredibly sensitive measuring kit, certainly not enough to make any measurable difference whatsoever to power or economy. If you want to shim it up, then fine, but if it isn't broken, why fix it?George.
I'm with George on this. I did mine because I had access to engineering equipment that allowed me to measure the gaps. I wouldn't have spent £10 doing it though. the side friction is negligible.
hello well, as you may know, I was once a marine engineer but that was some time ago and every engine I have seen or rebuilt has some form of Thackery spring washers but in our days most modern forms of engine do not with there 4 valves per cylinder and Doubleoverhead camshafts and oil pressurised bucket over the valve springs, but at the end of the day its all up to the individual that owns the motorcycle as members we can only advise, but do make sure thisdoes not shove the valve out of line, or to one side as it will make the valve guide to break up and maybe distort the cylinder head in this area,
yours anna J dixon
Dear Anna
If you read the thread carefully, you will find that it is not a question of
doing away with the "thackary" function !
It is replacing it with a (more) precise distance washer...
Bob
This is quite easy to sort out if you make up a test arbor to use instead of the rocker spindle when you do the actual fitting.
Arne
